Treg Hitch
Submitted: Wednesday, Apr 25, 2012 at 18:35
Member -Carl R (QLD)
I have a treg hitch on my caravan, the poly block is a little perished on the outer surfac.Has anyone replaced the poly block and how?
Reply By: The Bantam - Wednesday, Apr 25, 2012 at 20:23
Its probably not as bad as it looks, the degradation mots likley is only on the surface.
If you do want to replace it I understand you replace the whole block yoke and swivel pin as an assembly.
As I understamd it you drive the rolled locking pin out of the securing nut, undoo
the nut and withdraw the assembly.......replacement is the reverse, you may need to drill a new hole in the new pin and replace the rolled pin.
If in any doubt ring Treg on 08 8352 5177
484202
Reply By: Isuzumu - Thursday, Apr 26, 2012 at 15:12
Carl, for the best fix I would get rid of the Trigg and replace it with a DO 35 hitch from Vehicle Components. Especially on a van with higher tow ball weight, they are just so much easier to hook up with.
By the way how is the new BT 50? Have you done much towing and if so what sort of economy are you getting? thanks
484273
Follow Up By: Member -Carl R (QLD) - Thursday, Apr 26, 2012 at 17:47
Hi Isuzumu,Cant tell you much about the BT50 as we have only had it less than 2 weeks,but we find it a very smooth vehicle
759536
Follow Up By: Member - Boobook - Friday, Apr 27, 2012 at 11:18
Couldn't agree more Bruce. Great time to upgrade.
I would never use a Trigg/tregg again after the DO35. It is a ton easier.
759618
Reply By: Harry - Thursday, Apr 26, 2012 at 22:40
Mine started to lose chunks, so I replaced it with a Hyland hitch, everything is much easier now I can slide it onto a 50mm ball, instead of trying to line up that damn pin all the time.
Harry
484329
Reply By: Member - Gary J (NSW) - Friday, Apr 27, 2012 at 10:14
Hi Carl,
OzHitch have a conversion for Treg and AT35 hitches to their style of easy alignment hitch. Works out not much more than half price of the complete assembly.
I am thinking of upgrading my AT35 to an OzHitch for this very reason.
484353
