12 volt heaters
Submitted: Tuesday, Apr 17, 2012 at 17:10
johno59
Hi everyone. Does anyone know where to get a good quality 12 volt heater? thanks johno
Reply By: Member - Troll 81 (QLD) - Tuesday, Apr 17, 2012 at 17:42
I searches for ages and found nothing good, they all use so much power for very little gain. Ended up settling for some electric blankets that draw bugger all from my battery through a inverter.
483375
Follow Up By: Dennis Ellery - Tuesday, Apr 17, 2012 at 20:32
Was travelling around New Zealand a few years ago – met some local gypsies at a fair in Christchurch.
They travelled in a group, ran a small side show, buskers etc and for a $1 donation you could look through their mobile homes.
Mostly
home-made affairs on the back of old trucks – some had wood fired pot belly stoves inside.
758650
Reply By: rossy - Tuesday, Apr 17, 2012 at 17:58
DIESEL HEATER great in our
Kimberley Karavan
483379
Follow Up By: Cruiser .- Tuesday, Apr 17, 2012 at 18:24
I am in Victoria at the moment, and after 8 weeks in Tassie freezing our ar$es off we have been trying to find a dealer/repairer who can fit a diesel heater for us.
Most dealers are not interested, despite the fact that we wish to spend 2.5 to 3K with them and most repairers are booked up till end of June. Not real good when you are on the road and can't hang around.
I am seriously considering buying online and fitting it myself. would have to buy some el cheapo Bunnings
tools and then throw them away when finished, but at least I would get it done in a time frame that suits us.
BTW, very few dealers have them in stock.
Cruiser
758634
Follow Up By: Member - Josh- Tuesday, Apr 17, 2012 at 22:11
Cruiser, I'm in Cranbourne in Vic. If your fitting the heater while in Vic drop by and if I've got the
tools you need your welcome to use them. If not, feel free to leave the
tools you buy from bunnings here lol. Let me know if interested.
Josh
758667
Follow Up By: Travis22 - Wednesday, Apr 18, 2012 at 16:39
Great minds think alike Josh...
I was going to say the same thing.
I am located in Cranbourne Vic 3977! - If you need a hand, tools or space to work sing out.
Travis.
758724
Reply By: Member - John and Val - Tuesday, Apr 17, 2012 at 18:22
Johno - forget using 12V for ANY serious heating appliance. You simply don't have enough energy in your battery to provide any useful heating.
Works like this :
Power (watts) = volts x amps
A typical small radiator at
home will draw 1000 watts. Most electric jugs will draw at least 2000 watts.
How many watts in a battery?
Well, its not quite that simple but lets say you have a 100 amphour 12 volt battery, which is typical for camping use. In principle, (though not in practice) this might deliver 100 amps for an hour. If it delivered this at 12 volts (which it won't) that's 1200 watts. So IF it could be made to work, it might run a small radiator for a bit over an hour. In fact though you will probably use an inverter between battery and heater in order to get 240volts - at 80% efficiency the inverter might be expected (though it won't) to deliver 1000 watts for an hour.
BUT - you should never run a battery fully down as that will seriously shorten its life. The sort of deep cycle batteries we use when camping will not tolerate being discharged at 100 amps - they will get hot and bothered and die. They will not deliver 12 volts when hit with heavy loads. Realistically, you will not get your 1000 watts for an hour out of any 100 Ah battery.
There are members here with BIG systems - some with over 200 Kg of batteries with lots of solar panels to charge them. These people do run jugs for brief periods and maybe heaters too, but they have invested thousands of dollars in their systems.
Suggest try gas for any heating job - far cheaper and very effective.
Please read
Electricity for Camping. It will answer many of your questions about 12 volt electrics.
John | J and V
- Albert Einstein
483383
Reply By: Member - Jason B (NSW) - Tuesday, Apr 17, 2012 at 20:53
We
free camp mainly and make it a point to
camp away from others (just thought I would clarify that before all the nay sayers start). We have 2 kids 7 and 3.5 and use a 1800 Watt 240v heater and run it off our Honda EU20i. It works a treat and the Generators these days are very quiet. It will run through the night on a tank of fuel (it also charges our batteries during this time).
I have 210 Amps of batteries and am considering a couple of electric blankets to run off the inverter, but I need to confirm how much they draw etc before I jump in. As stated discharging the batteries fully is not good for them.
Jas
483407
Follow Up By: Member - Jason B (NSW) - Tuesday, Apr 17, 2012 at 20:54
Forgot to mention the heater was $20 and a number of saftey features built in that turn it off if it gets knocked over etc.
758657
Follow Up By: johno59 - Tuesday, Apr 17, 2012 at 21:23
Thanks Everyone. There a few Gas Heaters for internal use on the market. Apparently they have been tested for safty I know Jayco have had them from time to time. Might be worth following up johno
758663
Reply By: Bobjl - Tuesday, Apr 17, 2012 at 21:08
Johno - I had Dometic diesel heater in previous van and it worked
well. but it did not have a lot of use however I believe they are reliable and mostly trouble free provided clean diesel used. In my current Van I went to gas [Truma]. Google search gas heater caravan and you will find Truma easily. I have only used it a couple of times but it works very
well, seems efficient and warms up 22'6 van within 20 minutes from freezing outside temp. Mate recently retro fitted same make model in half a day but he is experienced gas fitter and as you will appreciate there are strict legal requirement for specialised skills when working with gas. It is not rocket science to fit the units [12 volt power, remote switch plus gas lines and some ducting inside and an exhaust to outside], but you need the specialist
tools and leak testing equipment/fluids to be absolutely certain it is safe so you must locate a licensed gas fitter, there are several in Melb area that do contract fit outs for custom van builders and will have fitted plenty of Truma gas units. The gas units are usually available [again search on line] and you will buy for less than $1800, fitting ought be less than say $400. Diesel heaters may be cheaper than gas now - not sure. I liked the fact that I did not need a extra tank for diesel. Some will prefer diesel for their own good reasons - choices!!!
483408
Reply By: Robin Miller - Tuesday, Apr 17, 2012 at 21:19
As explained by other posters ,essentially you can not but there is a work around.
Now we use a primus gas heater - almost the only practical portable device around but before that we would run a couple of infra heat lamp globes which project heat onto the body effectively - like bathroom heaters.
These globes run off 24ov and use about 300w each (25 amps @ 12v) giving about a hours run of typical car battery setup via your standard 600w inverter.
Worked really
well but for longers periods you then have to run of a gennie or have the car idling.
Have one running now at
home in back yard as kids are working on a trail bike in the cold night air.
483409
Reply By: JR - Wednesday, Apr 18, 2012 at 18:24
