Towbar Tongue
Just wondering if there is any reason why I should not invert the tongue on my tow hitch ie: instead of coming out and turning down then out it would be put in up the other way so as to come out then up then out again. Need the extra height to line up with caravan hitch. Caravan hitch 550mm from ground when level, vehicle only 460mm when tongue in normal, when turned upside down 550mm from ground to match van. Hope this all makes sense.
