Landcruiser rims
Submitted: Saturday, Apr 07, 2012 at 13:20
Mic B
Does anyone know if 16x8 5 stud landcruiser rims (op 5 on 150mm ) fit correctly on a 2008 VDJ78R TROOPIE.
Reply By: Member - Phil G (SA) - Saturday, Apr 07, 2012 at 16:06
They have to be off a rigid front axle (105series) Landcruiser. These went from 1998 to 2006 and had the 6 cyl petrol and normally aspirated diesel motors.
IFS rims from the fcatory TD and petrol V8 Landcruisers will not fit.
I expect you'll need flares.
482473
Follow Up By: Member - Phil G (SA) - Saturday, Apr 07, 2012 at 16:08
Here's a photo:
757719
Follow Up By: mike39 - Saturday, Apr 07, 2012 at 16:34
Sad,ey.
One of Toyota's best stuff ups.
Going from a "fit all" 6 stud to that 5 stud "one make only" configuration will make sure i keep the old 75 series of
mine going a long while yet.
mike
757721
Follow Up By: Member - Phil G (SA) - Saturday, Apr 07, 2012 at 17:53
Gday Mike,
Hate to tell you but most 6 stud rims out there will not fit your 75series.
They may have the same 6 stud pattern but the offset and centre hole differences means they won't fit or will reduce the track. The 40 and 60 series and very early hilux are the only factory rims that share the same offset as your 75series.
The 5 stud has a higher clamp pressure than the 6 stud because the studs are 14mm rather than 12mm, so they are less likely to break studs or come loose.
757728
Reply By: Mic B - Saturday, Apr 07, 2012 at 18:17
Thanks very much I think I have got a handle on this now.
482478
Reply By: Mic B - Saturday, Apr 07, 2012 at 18:20
Also photo very helpful. Thanks for taking the time might catch up on the wallaby
482479
Reply By: Rod W - Saturday, Apr 07, 2012 at 21:01
When i was looking for rims for my 2008 VDJ78 Troopy I came across the rims as per the above photo and I sure the steering linkage fouled up from those rims being used.
482486
Follow Up By: Mic B - Saturday, Apr 07, 2012 at 21:17
Can you remember if they were off a live axle or Ifs cruiser ? Thank you
757739
Follow Up By: Member - Phil G (SA) - Tuesday, Apr 10, 2012 at 18:28
Yes, the IFS rims have 60mm offset and the fronts will push up tight against the tie rod ends. The rears push against the leaf springs, so won't fit front or rear.
RFA 105series rims are zero offset (same as the factory 79series mags).
757961
