CUB camper - Escape - Tapfor kitchen sink
Submitted: Monday, Apr 02, 2012 at 19:07
ThreadID: 92969 Views:3016 Replies:2 FollowUps:0
I am hooking up 12 volt water to my CUB and I am having trouble finding a folding tap to fit. I would grateful for any ideas.
Milkman
Reply By: Member - John - Monday, Apr 02, 2012 at 20:44
G'day, try the Whitworths or BIAS Marine or the CAMEC catalogues, good luck.
John and Jan
AnswerID: 482191
Reply By: Member - bill f (QLD) - Monday, Apr 02, 2012 at 22:18
Hi, We had a CUB spacematic with a roll out sink & stove, Don't know what your set up is but ours had 2 taps. The pump from the tank & the other a folding one to connect to a hose. Tossed the hand pump away as it never worked properly. Installed 12v pressure pump behind the sink drawing from the tank & connected to the folding tap. Drew power direct from the battery(fused) through a switch.
Sounds like you don't have the folding tap so would suggest you contact CUB or as said a marine or caravan supplier. Bill
AnswerID: 482203
