Mouldy Mattress Advice
Submitted: Monday, Mar 26, 2012 at 15:34
Kieran R
I have a rooftop tent which I brought second hand. The lady I brought it off said i would have to look into ways of preventing mould growing underneath as she had had problems. Is there any quick, cheap and easy solutions?
Anything would be great!
Thanks,
Kieran
Reply By: Member - Troll 81 (QLD) - Monday, Mar 26, 2012 at 16:37
Hi Kieran,
I take it you are talking about under the mattress? I have never had that issue with
mine but I only do 1 or 2 nights in
mine and then it's back into the garage. I never pack it away if it's damp and if I have to I always open it up at home till it's dry.
481444
Follow Up By: sweetwill - Monday, Mar 26, 2012 at 17:01
Hello.
I do the same as troll never pack it away for long periods if damp but after saying that the" mattress" in
mine never gets damp, even on extended trips, bye for now Bill.
756812
Follow Up By: sweetwill - Tuesday, Mar 27, 2012 at 08:29
Hello again.
After reading more further down the page it sounds like a lot of roof top tents have aluminum bases,
mine is of a marine ply construction, Bill,
756865
Reply By: Member - John and Val - Monday, Mar 26, 2012 at 17:34
Hi Kieran,
There are some ideas
in this thread here. You may find other solutions by typing 'wet mattress" into the search box up in the top RH corner of the main
forum page.
From our experience, how damp a mattress will get depends largely on how much each user sweats at night. One of us sweats a fair bit and their side gets damp whereas the other side stays OK. Our solution (only partial though) has been to drill a few holes in the bed base - but in our case the base is inside the vehicle and no dust can come in. You may not have that option.
Another option may be to simply turn the mattress over every few days so the damp side can dry out - do it in the morning so it has a day to dry.
A damp mattress is a PITA as not only does it get mouldy but its very hard to warm up.
Val
| J and V
- Albert Einstein
481450
Reply By: miandering fiander - Monday, Mar 26, 2012 at 18:11
There is a product on the market for this, it looks like a scouring pad but very loose weave. Called Hypervent, google it and it will come up.
used a lot in C/Ts caravans and roof top tents.
481452
Reply By: Bill BD - Monday, Mar 26, 2012 at 18:27
I have found that high density foam mattresses don't get damp underneath. The cheap low density ones do.
481454
Reply By: Life Member - Phil B (WA) - Monday, Mar 26, 2012 at 18:39
Use Hypervent - it will fix your problem.
481456
Reply By: Member - Leanne W (NSW) - Monday, Mar 26, 2012 at 20:03
There is also something called EMP underlay - sounds like the Hypervent that others are talking about. We use it under the mattress in our campertrailer, and have never had a problem.
Leanne
481463
Reply By: Michael ( Moss Vale NSW) - Monday, Mar 26, 2012 at 20:38
The condensation under the matress can be major and if we are staying the next day after using it it night before, we simply pull up one side of the matress at 45 deg and rest one side against the inside of the tent to air it. We have found that if we pack up in the morning and drive all day, at the destination when we erect the roof tent again, the underside of the mattress is surprisingly dry!! Michael
481467
Reply By: Member - MIKE.G - Monday, Mar 26, 2012 at 20:50
Hi Kieran.
Had the same problem with our camper with a solid fibreglass bed base, particularly on cold nights in
the desert. Google "Air Circulation Mesh ACS10" and you will see what fixed the problem. There are only a couple of companies that sell it. We ended up getting it from Trayon - www.trayon.com for contact details - in Qld. They shipped it direct overnight. Not cheap but works a treat!!
Mike
481470
Reply By: Member - Warren R- Karratha - Monday, Mar 26, 2012 at 23:20
G'day Kieran
We travelled central Oz in 2 cars with rooftop tents and they both suffered from moisture under the mattress. My non-scientific opinion is that on cool nights the temp of the floor panel drops below dew point and the moisture in the air inside the tent condenses and wets the mattress. Exactly the same way dew forms on the outside of the car.
I solved the problem by lining the floor panel under the mattress with the plastic bubble wrap type vapour barrier used in roofs and for lining tin sheds etc. It only adds 6mm to the panel thickness and doesn't impede folding the tent. I just gaffa taped it in place.
Waz
481482
Reply By: Member - Roundie (N.S.W.) - Monday, Mar 26, 2012 at 23:23
Hi Kieran
Clark Rubber stores stock a mesh underlay which may
well be Hypervent. I purchased some as we have a foam mattress in our caravan and have never had a problem with condensation.
481484
Reply By: Member - Michael John T (VIC) - Tuesday, Mar 27, 2012 at 00:16
Hi Kieran,
We had same problem, mattress on aluminium base, solved it by putting those foam flooring/
camping mats used in annexes etc, they fit together are light and work.
regards,
Mike.
481485
Reply By: Member - Oldbaz. NSW. - Tuesday, Mar 27, 2012 at 08:31
I dont doubt the commercial products work, but so does doubled shadecloth....
at a fraction of the cost..fasten to ply with drawing pins....oldbaz.
481500
