Wednesday, Mar 14, 2012 at 02:49
The first link leads to the good one - the NZ-Wing
The second one does not work.
If you order through the third link you will most probably get the RV-Wing.
Make sure you get the NZ-Wing, it is cut to boost signals in the range 520 - 860 MHz (the Oz band.) The RV-Wing is cut to boost 470 - 700 MHz (the Yankee band.)
755800
