Plug and Play navigation system
Submitted: Tuesday, Mar 13, 2012 at 10:36
lj47
Hi All,
We recently purchased a Toyota 200 plug and play navigation and entertainment section and the instructions are less than helpfull, is there anyone out there with a set of simple instructions with writing that you don't need a magnifying glass to read, or can you tell me where to obtain one. Thanks
Reply By: TerraFirma - Tuesday, Mar 13, 2012 at 10:59
Did you buy it via Toyota? They should have given you instructions, these things are very easy to use. Unfortunately Toyota would make the instructions, if these aren't to your liking, I don't imagine anyone else having anything. Other than that Youtube is the best for getting easy demo's on how to use something as it's a walk you through. Once again if you bought it via Toyota you could also ask one of the service or sales people to demo you.
Here's a Youtube example, but this is a US version, but great way to learn
http://www.youtube.com/watch?v=HRO4BI8QXq8&feature=related
480253
Follow Up By: lj47 - Tuesday, Mar 13, 2012 at 12:34
Thankyou TerraFirma but it was an aftermarket one, but I will try youtube, thanks very much for your help.
755740
Follow Up By: TerraFirma - Tuesday, Mar 13, 2012 at 12:50
Type the model of your unit into Youtube and see how you go.
755742
Reply By: Member - Wayne B (NSW) - Tuesday, Mar 13, 2012 at 12:55
I fitted one to my 200GX a month or so ago.
I was given the following fitting advice from supplier as original instructions were crap
Hope some of this helps.
Amp - No need unless you have an amplifier
Brake - Earth it
Gnd - ground
Reverse - Connect to positive of your reverse light
Bat 12v out - Ignore – it’s if you’re running another 12V device light a digital tv receiver.
Ccd 12v out - Ignore
Ad1 - Ignore – for steering which is in the plug already
Ad2 - Ignore – for steering which is in the plug already
Ant cont - Ignore – for digital tv
Tv cont - Ignore – for digital tv
Black Plug to Camera. Where do Red and Black wires go – Red to positive of reverse light and black to negative
Other end of Camera wiring harness. Yellow and One Thin RED wire where do these go –Yellow plug to CCD-IN, red wire to Reverse
All the TV type plugs are not used except for the Rev Camera Output
They are really just Plug and Play.
Good Luck Wayne B
480258
