Gu 4.2 Patrol Air Filter, Which wau up?
Submitted: Saturday, Mar 10, 2012 at 17:01
kwk56pt
Am I correct in installing my air cleaner element with the thick seal upwards.? Its a ryco element in a 4.2 GU 2005 Patrol.
Reply By: Michael ( Moss Vale NSW) - Saturday, Mar 10, 2012 at 19:45
The harder rubber seal goes to the bottom and the soft foam goes to the top.. The theory is that the rubber seal will support the weight of the filter and the foam will seal the top cover.. Michael
| Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.Member My Profile My Blog Send Message |
480059
Follow Up By: kwk56pt - Saturday, Mar 10, 2012 at 22:57
My filter is a. The thin seal appears to be the hard rubber one and the top one a thicker rubber/ foam. The thicker seal is reasonable hard but will compress. I assume the thicker seal is the one you believe should be on top. I will have to buy a genuine filter ..to see what the difference is as I think of foam as being much softer.
I appreciate your reply as the filter orientation was not clear in the manual.
755570
Follow Up By: Michael ( Moss Vale NSW) - Saturday, Mar 10, 2012 at 23:20
Yes!! The hard rubber is the bottom seal, and the foam goes to the top! Michael
| Patrol 4.2TDi 2003
755573
