Saturday, Mar 10, 2012 at 23:05
Hi Phil, I'll have a crack at explaining "auto unlocker", using a diff ratio of 4 to 1 and just using the rear diff, NOT in 4WD
When you turn a corner with a normal diff, the wheels on the inside turn slower than the wheels on the outside, outside wheels still stay at 4 to 1, however to inside wheels turn slower to compensate the arc of the turn.
When you turn the same corner with a locked diff, both wheels will want to turn at the same speed,which is why you will get the "pushing sensation" thru the steering, both back wheels are fighting against each other, that's where airlockers come into play, having the ability to turn off.
With an auto locker when going straight ahead, the diff is locked, both wheels are turning at 4 to 1 compared to driveshaft, when you come to the same corner as mentioned, the INSIDE wheel stays turning at 4 to 1 (remembering, normal diff, wheel would slow down), the outside wheel then has to "speed up" releasing the ratchet mechanism.
The Autolocker will not allow any wheel to turn slower than what the driveshaft (4 to1) is turning at, it ONLY unlocks when one wheel begins to turn faster than 4 to 1.
Might take abit to get your head around, took me awhile
Shane
755572
