Suspension Upgrade
Submitted: Saturday, Feb 18, 2012 at 17:54
Member - Tony Z (NSW)
Hi all,
Some of you all knowing travellers will be able to help me (I hope).
We have a 2009 NS Pajero DiD LWB. It has an alloy ECB bar (no winch) dual batteries up front, no draws in rear so no weight in back all of the week( but do carry recovery gear in 3rd row
seat well all the time just in case)
The question is :- I want to get a 50mm lift so what springs should I fit front & back. I have purchased a full set of Bilsteins so I now need springs to suit, I was thinking for the FRONT- Kings or Lovells HD & REAR- Kings progressive rate or would Lovell SD and Air bags be better for a softer ride (as we have a Camper Trailer with a ball weight of 80-90kg loaded.
We getaway about once a month for w/k ends with two 4week trips a year. We try and
free camp as much as possible, and the rear has a medium load when we travel
All replies greatly appreciated
Reply By: Member - Jeff C (NSW) - Sunday, Feb 19, 2012 at 00:52
Gday Tony
We've got an NP Exceed DiD with dual battery, fridge, draws, 3rd row
seat removed.
We installed Tough Dog shocks and 2" lift springs standard duty front and rear. They are slightly heavier than the original ones. Plus poly airbags.
The ride is a lot better than original and when we load it up to go camping plus 4 bikes hanging off the back and the roof basket full, the bags maintain the ride height (just).
I'm very happy with the setup, but if I was going to tow a decent size trailer I'd look at HD springs on the rear maybe.
I have been in a NP with no drwas or fridge with HD King springs and the ride is very harsh.
I'm sure whatever you end up with will be an improvement.
Jeff
478100
Follow Up By: Member - The old fellow - Sunday, Feb 19, 2012 at 07:56
Hi Tony Do as I did and go to your ARB man give him all your weights etc and he installed a complete set of OME springs and matching shocks. 50mm lift and I could not be happier with the result, best of all when I had a slight problem months later when thousands of ks from
home, took it to ARB dealer in
Darwin who within hours fixed the problem with a new shocker and all for no charge. Great service. That after sales service meant a lot to me and it was
well worth paying the bit extra.
753568
Follow Up By: Member - Tony Z (NSW) - Sunday, Feb 19, 2012 at 09:44
Thanks Jeff I have decided to go HD 2" lift all-round as I am adding some rear protection plates to the rear of vehicle, also read on Paj. site that some people have had some trouble with air bags pinching/rubbing (not under inflated)
Again thanks
753573
Follow Up By: Member - Tony Z (NSW) - Sunday, Feb 19, 2012 at 09:47
The old fellow thanks
But I already have the shockies only require Springs. dont think they will cover shocks when just fitting Springs
753574
