Lifting holden rodeo
Submitted: Sunday, Feb 12, 2012 at 21:53
MTN Dan
can you lift a holden rodeo 2 inches by just a lift kit or do you have to change
suspension etc
Reply By: Member - Bucky - Monday, Feb 13, 2012 at 07:43
MTN Dan
I lifted our 2003 Navara, which has almost identicle
suspension, so why not the Rodeo. We ended up 52mm on the rear, with a new Ride Pro HD Spring kit, and 28mm on the front., by simply winding up the original torsion bar. Any more wind up on the torsion bars, would have adversly effected the travell of the front.
Keep in mind that you may have to
1) Resret, or replace, the rear springs.
2) get Extended, greasable shackles
3) Winding up torsion bars, can be done, but remember the twist needs to help up as
well as down. However there are stronger torsion bars on the market, to accomodate this too.
Bucky
477617
