Au Front Seats in 80 Series
Hello Everyone, Sorry to drag up an old topic but I have recently got a pair of au seats in mint condition for a song... I have read the archives and seen where a few people have installed them in their own 80 series. just wondering if anyone has some pictures of the modification. Really would appreciate any help. Thanks in advance.....
Reply By: Shaker - Saturday, Feb 04, 2012 at 21:00
You will most likely need to get an engineers certificate.
AnswerID: 476891
Follow Up By: Tim L1 - Saturday, Feb 04, 2012 at 23:58
Thanks for the reply Shaker, I was thinking the same thing,but just wanted to see what others have done...Cheers
FollowupID: 752054
Follow Up By: Member - Royce- Sunday, Feb 05, 2012 at 08:58
You only need engineering if you ever want to sell, or comprehensively insure.
Otherwise there is little likelyhood that there would be an issue. Keep the old seats to swap back if necessary.
FollowupID: 752083
Follow Up By: Shaker - Sunday, Feb 05, 2012 at 09:36
..... or to prevent yourself from being held solely liable in the event of a failure in an accident that injures a passenger, insured or not!
FollowupID: 752091
Follow Up By: Member - Royce- Sunday, Feb 05, 2012 at 09:39
Good point Shaker. Life does have its risks and another valid worry. I wouldn't be though.
Having said that, I never let my grandson ride on the tractor with me as I did my son. So levels of risk and worry do change over time.
FollowupID: 752092
Reply By: Member - DickyBeach - Saturday, Feb 04, 2012 at 23:50
Hi Tim,
I feel like an ignoramus. I've owned an 80 for 12 years and have never heard of an "au seat".
Please educate an old bloke and tell me more.
DickyBeach
AnswerID: 476908
Follow Up By: Tim L1 - Sunday, Feb 05, 2012 at 00:09
Hey there DickyBeach, just up the road from you at Mooloolaba, The au seats are out of a Ford Au series 3 sedan, Sorry I should have been a bit more clearer on that. Cant beat an 80 series, I have a 1992 1HDT rebuilt the motor at 245000klms after Toyotas cheap white metal bearing locked onto the crank.When I removed the pistons you could still see the hone marks in the cylinders as if it was still new. Cheers
FollowupID: 752055
Reply By: Rockape - Sunday, Feb 05, 2012 at 07:22
Tim,
although these are 75 series Troopcarrier photos I believe the principal will be the same.
I have fitted a 78 series drivers seat to the passenger side of the troopy. In doing this the seat sits to far to the right and I have moved it 50mm toward the door.
You will probably have to put in a plate as I have to allow the use of your 80 series seat runners and the fixings in the ford seats can then be bolted through the plate.
I my case I have used 6mm aluminium plate for the seat to bolt too. I have also fitted 78 series seat runners that allow the seats to travel about 40mm further back.
Here are a couple of photos.
Image Could Not Be Found
All the bolts and nuts are high tensile grade 8.8
Hope this helps,
RA.
AnswerID: 476930
Follow Up By: Rockape - Sunday, Feb 05, 2012 at 07:28
Sorry about the wrong photo I will post the right one.Image Could Not Be Found
FollowupID: 752066
Follow Up By: Tim L1 - Sunday, Feb 05, 2012 at 07:58
Thanks very much RA, great pics , the 6mm aluminium plate is a great idea. This puts a whole new spin on what i was thinking, always pays to get other peoples suggestions.
Regards Tim
FollowupID: 752075
Reply By: howesy - Sunday, Feb 05, 2012 at 07:47
My son has AU XR8 seat in his 80 and he reckons its great.
AnswerID: 476932
Follow Up By: Tim L1 - Sunday, Feb 05, 2012 at 15:54
Thanks Howesy, the au seats are very comfortable and with lumber support, Lower and raise seat plus tilt cant go wrong. the old GLX seats are not the best very uncomfortable.
Cheers Tim
FollowupID: 752155
Reply By: rumpig - Sunday, Feb 05, 2012 at 12:11
maybe speak to a local engineer who will be signing off on the work first and see what he wants done, i did this when i put new seats in my 105 series. the actual blue plating by the engineer cost less then $150, i had to go to Qld transport next and do some paper work there because i changed from a 6 seater to a 5 seater, not sure if you'll need to do any paperwork with them, but best to check, there was no cost involved at Qld transport.
before you remove your old seat, maybe do as i did and measure how high your head is from the roof of your vehicle, sit the new seat in place and check if there is much differance between the 2 seats. i ended up using some box section steel to raise the height of my seat as it sat about 50mm lower in the new seat before modding it.
AnswerID: 476973
Follow Up By: Tim L1 - Sunday, Feb 05, 2012 at 15:59
Hey Rumpig, Thanks for the info, got some ideas so i will run them past a engineer and see what he thinks and make sure its all ok. I have measured all the heights and widths compared to original seats, the only difference is the top of the seat at its widest point is 30 mm wider which will be fine.
Cheers Tim
FollowupID: 752157
Reply By: Tim L1 - Sunday, Feb 19, 2012 at 13:51
Thanks to everyone for the great replies, Finally got them all installed not so easy but very happy with the end result and wow are they comfy......I ended up mounting them using 6mm ally plates (Big thanks to Rockape for the pics) and some modifications to the original runners. no need to spend big $$$$$ on after market seats just install the AU Seats and your on a winner........
AnswerID: 478133
