Who has Parabolic springs in thier truck?
Submitted: Wednesday, Feb 01, 2012 at 07:27
Member - Tour Boy ( Bundy QLD)
Hi All,
Who has a set of parabolic springs in their truck?
How is the ride? How is the pitchiness?
I had the original Toyota factory parabolics in the rear of my 4wd coaster and it rode great. I am thinking of running them in the troopy for comfort and wheel travel, so I'm looking for
feedback from others.
Reply By: PeterInSa - Wednesday, Feb 01, 2012 at 10:14
In my opinion there will be great when you have a load in the back and a bumpy ride when the vehicle has no load.
476563
Follow Up By: Member - Tour Boy ( Bundy QLD) - Wednesday, Feb 01, 2012 at 20:00
Hi Peter,
Have you had a set? They are generally designed to give a soft ride at all times just after confimation of this.
751719
Reply By: garrycol - Wednesday, Feb 01, 2012 at 10:38
I have original parabolics on my landrover truck and it rides better than a smaller cart sprung landrover. However because my vehicle is designed to carry 1.5t there is not a lot of wheel travel when empty. Put a ton in it and it rides
well with full wheel travel.
Make sure
the springs you get are matched to the weight and load carrying capability of your vehicle.
Garry
476565
Follow Up By: Member - Tour Boy ( Bundy QLD) - Wednesday, Feb 01, 2012 at 20:01
Hi Garry,
Are yours a LR fitment or aftermarket? If Aftermarket, who made them?
751720
Follow Up By: garrycol - Wednesday, Feb 01, 2012 at 22:22
Mine are original fit made by landrover - each spring only has two leaves and are quite thick.
751745
Follow Up By: garrycol - Wednesday, Feb 01, 2012 at 22:33
Rocky Mountain in North America make aftermarket parabolics for Landrover so I also assume Toyota - FWDs in Qld are a distributor for them.
Parabolics can handle heavy loads - as I said I can carry 1.5t in
mine - but most after market parabolic springs do seem to have issues with big loads - I think the makers seem to compromise capacity for ride but both are achievable with properly designed springs.
Garry
751747
Follow Up By: Member - Tour Boy ( Bundy QLD) - Thursday, Feb 02, 2012 at 16:28
Hi Garry,
I'll look them up.
751807
Reply By: Kanga1 - Wednesday, Feb 01, 2012 at 11:13
Hi Dave, I had Parabolics in the back of my Troopy, good flex when not loaded, I found them unsuitable for consistant load carrying. The first part of spring travel when unloaded is quite soft until they flatten out to the big Parabolic spring, in all not bad. I have replaced my parabolics ( which are in the Quokka) for Kings Heavy duty 60mm lifted leaf packs, which should suit my applications better> Cheers, Kanga.
476570
Follow Up By: Member - Tour Boy ( Bundy QLD) - Wednesday, Feb 01, 2012 at 19:58
Hi Kanga,
Did you have them set up for a constant load?
I will only have a max of 100kg in the back on a trip as the weight will be in the trailer. The rest of the time it has basically about 30kg max. How were yours when empty and where did you get them from?
751717
Follow Up By: Kanga1 - Wednesday, Feb 01, 2012 at 21:42
Hi Dave, I had them supplied and fitted by Wilkinson Suspensions here in WA. I think the brand was APM springs, Malaysian made.
The springs were quite good with the vehicle unloaded, good wheel articulation. My Troopy is quite heavy unloaded, Kaymar dual wheel rear bar, 2 wheels, full length Trade height drawer set with about 30kg in them all the time. When we go away the cars weight increases by about 250kg give or take 30kg. We are going to buy a Caravan in the near future to replace our Tvan, and the weight on the hitch for the vans we are looking at is around 225kg. Having read all the blurb from Hayman Reece about WD Hitches and Kaymar's info on these Hitches, I decided to put heavy duty leaf packs in the rear instead, and keep it at that. The Parabolics are not suited to my intended use. As a rule of thumb,
the springs should be good provided you are not too heavy. Hope this helps you a bit, Cheers, Kanga.
751737
Reply By: TrevorDavid- Thursday, Feb 02, 2012 at 15:22
Tour Boy,
I have them in my 79 series for a few months now. The wheel travel is excellent , the ride is great loaded or unloaded ( I have not had the truck fully loaded as yet but but close to it ) Unloaded I do get a little bit of sway or body roll, nothing alarming. I do not tow and probably would not with parabolics underneath.
TDB
476663
Follow Up By: Member - Tour Boy ( Bundy QLD) - Friday, Feb 03, 2012 at 07:05
Hi TDB,
Thanks, Who supplied yours?
751879
Follow Up By: TrevorDavid- Friday, Feb 03, 2012 at 11:26
Westralia springs in
Perth. www.westraliasprings.com.au
TDB
751909
Reply By: Ross M - Thursday, Feb 02, 2012 at 18:06
Just a question to people on this thread.
Is Parabolic a brand name or is it a spring type somehow different to the originals in the vehicles we are talking about.
All leaf springs are parabolic I thought and I don't know what the differences may be.
Ross M
476672
Follow Up By: garrycol - Thursday, Feb 02, 2012 at 19:56
If you look on Wikapedia you will find;
A more modern implementation is the parabolic leaf spring. This design is characterised by fewer leaves whose thickness varies from centre to ends following a parabolic curve. In this design, inter-leaf friction is unwanted, and therefore there is only contact between
the springs at the ends and at the centre where the axle is connected. Spacers prevent contact at other points. Aside from a weight saving, the main advantage of parabolic springs is their greater flexibility, which translates into vehicle ride quality that approaches that of coil springs. There is a trade-off in the form of reduced load carrying capability, however. The characteristic of parabolic springs is better riding comfort and not as "stiff" as conventional "multi-leaf springs". It is widely used on buses for better comfort.
751833
