Thursday, Jan 26, 2012 at 13:39
Hi Chris - you're partly right -
Australian Gas Bottle Standards
In Australian Standard AS 2469 - 2005, the categories which are stamped (numbers 1 to 4) in a circle on the top of the cowall surrounding the valve assembly on gas bottles are as follows:
1 Hot Dip Galvanizing
2 Abrasive blasted + inorganic zinc rich coating + organic zinc rich coating.
3 Sprayed Zinc Coating
4 Red oxide or polyester powder coat.
The numbers refer to the rust proofing treatment of the steel, not the thickness of the steel. Obviously, the thickness of the treatment will vary eg hot dip galvanising is thicker than powder coating.
The Australian Standard requires all gas bottles manufactured in carbon steel to have a wall thickness of 1.75 mm and be tested to a minimum pressure of 320 Mpa.
The only exception is gas bottles manufactured in stainless steel are to have a wall thickness of 1.5 mm, and be tested to a minimum pressure of 360 MPa.
Stainless steel would probably be the best for caravan usage, but they are likely to be quite expensive. So, when exchanging gas bottles, the number 1 in the circle should be preferred. The number 2 bottles should be the minimal treatment for caravan usage. The number 3 and the powder coated type with number 4 in the circle should be restricted to
home use.
Mh
751070
