off road trailer springs made by industrial springs in adelaide
Submitted: Friday, Jan 13, 2012 at 23:50
Swaggy1963
Hi all just wondering if anyone has had experience with these springs they seem to be pretty good the salesman explained that spring makers all rate there springs differently and that there 1500 kg springs would handle 1500 kg comfortably and for example alco outback1500 kg springs rate there springs at 1500 kg yet they only have 7 leaves 2 less than the std off road spring made by industrial springs so i would say alco have rated theres as the maximum load that there springs will take so any
feedback from people that have off road springs made by industrial springs would be most welcome.
Andrew
Reply By: Peter_n_Margaret - Saturday, Jan 14, 2012 at 06:25
I have had springs made by Industrial Springs for the OKA. I reckon they know their business.
I would choose springs with good travel and a softer ride than those normally fitted to OR trailers. That will mean maximising the length. The number of leaves required for a particular load depends on several factors, including width and thickness and length.
I would also fit shockers.
OKA196 Motorhome.
474876
Follow Up By: Peter_n_Margaret - Saturday, Jan 14, 2012 at 06:27
If you want to talk to a non salesman, sneak in the back from the side street and talk to Pedro. He makes
the springs and knows his stuff too.
749823
Follow Up By: Shaker - Saturday, Jan 14, 2012 at 09:44
Finally, someone with some commonsense about springs!
Everybody seems blinded by the number of leaves required, if
the springs don't flex, the shock absorbers are getting a free ride, it is that simple.
749837
Reply By: RobAck - Saturday, Jan 14, 2012 at 16:42
No experience of
the springs but plenty of experience with the company. They know their stuff and if you take a look at Jol Flemings website he recommends them as
well
RobA
474903
Reply By: Member - Phil G (SA) - Saturday, Jan 14, 2012 at 20:30
I've bought most of my springs from Industrial Springs on Port Rd for the past 30 years - both trailers and 4wds. Great company - one of SA's best kept secrets! Never had a problem.
474918
Reply By: Stewy - Saturday, Jan 14, 2012 at 21:29
Have ther springs on both my 79 series and van , even took the truck ones back and had them reset when the did not do the job asked, nothing but good service and follow up
474926
Follow Up By: Member - Phil G (SA) - Saturday, Jan 14, 2012 at 21:32
Interesting Stewy,
I went to them 6 years ago for springs for my 79series - they said they do springs that support plenty of weight, but I was looking for articulation or soft ride, i'd be better off going to one of the 4wd suppliers. I appreciated their honesty.
749908
Follow Up By: Stewy - Sunday, Jan 15, 2012 at 20:37
Went to them in 2008, was after original height and clearance after new tray was fitted as I was getting wheel strike on the tray on rough terrain. end result was a better ride, all be it a little rough when not loaded, very happy was a good comprise. So far I have done the Canning, Googs and Canunda plus numerous small trips with no complaints.
Stewy
749977
