Question: Tyre Size Calculator
Submitted: Saturday, Jan 07, 2012 at 23:26
Seeking Adventure
Hi Guys!
Have someone tried a Bridgeston Dueler D694 (225/75 r15) or similar size tyre in a Mitsubishi Challenger? (My is a 2002) model.
Reply By: Member - Doug T (NT) - Sunday, Jan 08, 2012 at 06:41
Check this out..
D694LT Testimonials
474347
Follow Up By: Seeking Adventure - Sunday, Jan 08, 2012 at 15:21
Thanks for your help Doug!
Sounds good to me and probably I'll buy it. But I still not sure about the size?! The original tyre size in my car is 265/70 r15 and the D694 that I want are 225 or 235/75 r15.
749309
Follow Up By: ross - Sunday, Jan 08, 2012 at 18:01
Im happy with them,not sure Ill get the 80000-90000klms mentioned in the testimonials though.
749320
Follow Up By: Member - Doug T (NT) - Sunday, Jan 08, 2012 at 21:18
Have a look at this one. Bridgestone D683 (265/70R15) , it has a good tread pattern too.
Dueler H/L D683
749339
Reply By: Member - Tony V (NSW) - Sunday, Jan 08, 2012 at 15:42
Hey Seeking,
Tyre Calc
example
Tyre Size Difference Comparison
Select Wheel/Tyre 1 / R 265/70/15
Select Wheel/Tyre 2 / R 235/75/15
Results for your selected Wheel/Tyre 1
Rolling Radius 376mm
Circumference 2362.48mm
Diameter 752mm
Wheel Cover Size Size 005
Results for your selected Wheel/Tyre 2
Rolling Radius 366.75mm
Circumference 2304.36mm
Diameter 733.5mm
Differences between Wheel/Tyre 1 & 2
Rolling Radius -9.25mm
Circumference -58.12mm
Diameter -18.5mm
When your speedo reads 100km/hr you're actually at 97.48 km/hr
474385
