Memory Map and Hema Maps on 3G iPad2
Submitted: Tuesday, Jan 03, 2012 at 13:41
ThreadID: 90983 Views:2528 Replies:3 FollowUps:7
Anyone using Memory Map with Hema Maps on their 3G iPad2? If so do you like it? Has anyone done a long trip using it?
Dick
Reply By: Michael A (VIC) - Tuesday, Jan 03, 2012 at 15:30
Sure have, it worked really well on a 5 week trip up into Arnhem Land from Melbourne. I had the iPad mounted on a windscreen suction cup mount. It came off once, on the way to Big Red, but no other drama to report.
I didn't open a paper map for the whole trip.
Make sure before you leave home you download all of the maps you will be using.
Michael A
AnswerID: 473947
Follow Up By: Michael A (VIC) - Tuesday, Jan 03, 2012 at 15:40
We also used the iPad to back up our photos each day, play music in the car (through the FM tuner) and take a few videos overtaking road train and river crossings.
From memory, we always had it plugged into a power source, either 12v socket or inverter, so the battery stayed well charged.
Michael A
FollowupID: 748777
Follow Up By: Bonz (Vic) - Tuesday, Jan 03, 2012 at 17:05
How dya get it in there? I have a iPad2 Memory maps app and the hema m aps also but not together
FollowupID: 748782
Follow Up By: Michael A (VIC) - Tuesday, Jan 03, 2012 at 17:14
I bought them through the Hema Maps through the Digital Store in Memory Map. Not sure how you would do it if you have them separately.
FollowupID: 748783
Follow Up By: Michael A (VIC) - Tuesday, Jan 03, 2012 at 17:26
That doesn't read well. In Memory Map, there's a Digital Map Store option. I bought the Hema Maps license, Australian Topo and the Hema 4Wd maps.
FollowupID: 748786
Follow Up By: Bonz (Vic) - Tuesday, Jan 03, 2012 at 17:58
Thanx Michael, I understand, and yep it'd be easier if you did it thru memory maps etc but its plain silly I reckon and a ripoff if you have the software and just want to employ a different medium. I use hema via Ozi, so should I be expecting too much to be able to use it via MM on the iPad? probably
FollowupID: 748787
Reply By: mikehzz - Tuesday, Jan 03, 2012 at 18:55
The only problem I have had with the ipad and Memory Maps is that some car chargers won't charge the ipad very well and it gradually goes flat even while on the charger. The GPS uses a fair bit of juice as does the screen being on all day. Make sure you buy a car charger that specifies IPAD not just iphone/ipod. Otherwise it will show you around all day and conk out at night :-)
AnswerID: 473971
Follow Up By: Member - Boobook - Wednesday, Jan 04, 2012 at 15:24
There is a Belkin one that supplies about 2.5A, I saw it for $26.00 in JB Hifi
FollowupID: 748895
Reply By: barely there - Wednesday, Jan 04, 2012 at 11:47
Hi there,does anyone know if the Hema map comes with a locator,ie. to show where you are on the map??
Am interested but do want this feature.
AnswerID: 474027
Follow Up By: mikehzz - Wednesday, Jan 04, 2012 at 16:36
All of them do that provided the ipad has the gps chip and therefore the 3G model? Is that what you meant?
FollowupID: 748901
