Touch up paint for Ulitimate Xtrk
Submitted: Monday, Jan 02, 2012 at 22:54
ThreadID: 90975 Views:2714 Replies:5 FollowUps:0
Hi, we have an Ultimate Xtrk (which we absolutely love) and are after touch up paint for the grey are around nose (stone guard). It has be worn with stones and wanting to keep it looking oood. If anyone can help, that would be great we are in wa but happy to purchase online if needed, Thx
Reply By: Ross M - Monday, Jan 02, 2012 at 23:51
Most reputable automotive paint shops will mix a small spar can of your colour if you give them the paint code ID from your vehicle id plate under the bonnet.
It usually lists items like Trim no. and Paint id no. and other info as well.
Cost should be around $30 - $40 and also ask them for any advice in performing the touch up process.
Best Regards
Ross M
AnswerID: 473913
Reply By: Shaker - Tuesday, Jan 03, 2012 at 09:29
Have you considered contacting Ultimate?
Is the area steel or fibreglass, if it's fibreglass it is most likely gelcoat.
AnswerID: 473927
Reply By: Member - Frank P (NSW) - Tuesday, Jan 03, 2012 at 11:44
My mate had one of those and it suffered badly from gravel rash behind his 100 Series.
Rather than paint, you might be better off, if you can afford it, to get it treated with Rhino Lining. This is an extremely tough, stone-resistant textured coating that can be applied as thick or as thin as you like. The factory put it on the front of our fibreglass camper, done 40,000km of off-road touring and all it needs is tyre-black to bring it up again.
http://www.rhinolinings.com.au/auto/
No affiliation, just advising of a known good product.
Frank
AnswerID: 473935
Reply By: Peter McG (Member, Melbourne) - Tuesday, Jan 03, 2012 at 12:45
Hi Gouldsie
If you drop over to the Ultimate forum you'll get several suggestions from Ultimate owners. Contact Ultimate for access if you don't have it right now.
I use 3M stone and chip protector, water based and you can apply with a brush.
VKS Mobile 1906
AnswerID: 473941
Reply By: Member - Bucky - Wednesday, Jan 04, 2012 at 06:06
gouldsie
Are you sure that the protective coating is not actually a rubberised paint ?
What do Ultimate themselves say ?
AnswerID: 474015
