Battery Water
Submitted: Monday, Jan 02, 2012 at 15:50
Witi Repartee
A year ago my beloved and daughters bought me a small tropical fish set up, because one night, after a cold ones I was silly enough to reminisce over fondly of an aquarium I had set up many years ago in another country.
I have learnt my lesson!!!
Can I use
the aquarium water conditioner and PH down/up to remove chloride and heavy metals and adjust the water for my vehicle batteries? Is there any advantage in doing this and if so, do I adjust the water to ph neutral etc?
Cheers and thanks
Reply By: Notso - Monday, Jan 02, 2012 at 16:51
Nope, buy the correct stuff.
473883
Follow Up By: get outmore - Monday, Jan 02, 2012 at 17:40
To elaborate most fish dont liie water to pure and need the dissolved minerals ive killed archer fish using rain water
748729
Reply By: landseka - Monday, Jan 02, 2012 at 17:51
A bottle of distilled water is not expensive, why risk damage?
Cheers Neil
473888
Follow Up By: Witi Repartee - Monday, Jan 02, 2012 at 18:41
Points taken...thanks guys. I guess in my case it's just a case of habitual DIY and curiosity. Also the kitchen tap is always closer than the Auto Supplies outfit.
748736
Follow Up By: Member - MUZBRY(Vic) - Monday, Jan 02, 2012 at 18:57
Gday Witi ;;;;;;
Thats what i would have done, the old kitchen tap
748737
Follow Up By: dbish - Monday, Jan 02, 2012 at 19:04
I only use rain water from an underground tank for batterys, & get from 6 to 10 years from N70ZZ baterys in my vehicles. One is used for the caravan for power & Waeco fridge. I only buy $100 baterys from local Sprint store. I notice now they are $125.
748739
Reply By: The Bantam - Monday, Jan 02, 2012 at 19:15
The issue with battery water is not the chlorine or the PH, it is the mineral content.
Uncontaminated rain water can be used...there may be issues with rain water that has come from galvanised ( zinc) roofs gutters or pipes, or that has been stored in metal tanks.
If the rain water has come out of a concrete tank lime may be an issue.
Far better to use demineralised or distilled water, or water that has come out of a decent reverse osmosis filter.
473892
Reply By: Witi Repartee - Monday, Jan 02, 2012 at 19:56
Does boiling tap water remove any dissolved minerals / gases etc.
473898
Follow Up By: landseka - Monday, Jan 02, 2012 at 20:15
I don't know about gasses but minerals won't be removed by boiling, if fact they would become more concentrated (less liquid - same minerals).
Cheers Neil
748746
Follow Up By: Member - Welldone (WA) - Monday, Jan 02, 2012 at 21:19
Boiling does remove some minerals, look inside a
well used kettle at the amount of calcium type build up on the internal surfaces. Most gasses come out of solution when water is boiled.
Welldone
748751
Follow Up By: Member - MUZBRY(Vic) - Monday, Jan 02, 2012 at 21:20
Gday
You have to catch the condensation and use that.
748752
Follow Up By: Member Andys Adventures - Monday, Jan 02, 2012 at 21:31
I use a large plastic bucket and leave outside when raining then fill plastic bottle, Once water has come into contact with metal it is no good for your battery, glass is ok as
Andy
748753
Reply By: Member - Bucky - Tuesday, Jan 03, 2012 at 04:30
De ionized water, I believe is correct
Bucky
473922
Reply By: Witi Repartee - Tuesday, Jan 03, 2012 at 20:31
thanks for the comments. Looks like there are no easy DIY options.
473982
