spares and extra's
Submitted: Wednesday, Apr 03, 2002 at 00:00
Jeff Harwood
Hi all. have just sold our business and are planning to head of around OZ for at least 2 years. My questin is, what do you all think are the "must have's" as oposed to the "would like to have's". We are travelling in a '96 L/R Disco that has been modified with the following;
raised 45mm allround, Kamar rear bumper with spare,
snorkel, dual battery, rear rollar _Affordable_Storage_Drawers.aspx, full length Overlander roofrack, 16" 235/85 Cooper STT + 2 spares, 85lt Flexi tank (H2O), 95lt fuel tank, 2 x 32lt Engel fridges (1 for freezer), XD9000 Warn winch mounted on ARB bullbar,Garmin GPS Plus II and software, high lift jack and all recovery equipment.
Anything else that you recommend? we are also going to be towing a 3.6mtr alli dingy. We would like to be able to access everywhere.
All responses are appreiciated. Thanks for your input.
Reply By: Mark Wilson - Wednesday, Apr 03, 2002 at 00:00
Jeff, you've got most of the "must have's" pretty
well covered. I'd like to see you include bead breakers or similar and some way of charging your batteries external to running your vehicle. Two Engels will quickly "drain" your auxilliary battery provisions. Look at either a solar panel or Les Christie's charger. A 50cc Honda 4 stroke mated to a 55 amp bosch alternator. Weighs in at 12 kg and has received rave reviews by range of groups and individuals. What abour communication equipment? Regards Mark
Wilson
2594
Reply By: steve - Wednesday, Apr 03, 2002 at 00:00
Reckon a good HF Transceiver would be a must to keep in contact with VKS 737 for road conditions and general communications...
steve
2596
Reply By: Phil Piesse - Wednesday, Apr 03, 2002 at 00:00
G'day Jeff. At the risk of sounding like a worn old record, your tyres, with an increase in diameter of more than 15 mm over standard will render your Disco unroadworthy and, more importantly, void your comprehensive insurance in most Australian states. I've just about ground away both my diffs and would like nothing better than some 215/85's !
Have a great trip !
2597
Reply By: Gordon - Wednesday, Apr 03, 2002 at 00:00
Jeff, consider 4 things, (i)tyres, (ii)comms, (iii)weight and (iv)range. TYRES: Tyres are the most vulnerable part of any 4WD. I would feel unprepared without spare tubes(3),
puncture repair kit, bead breaker, tyre levers, rubber mallet and a compressor. In the outback it is not uncommon to get more than two punctures before you get to the next town (I've had 3 myself and once met a guy who had 4 in one day.) You will also need to reduce tyre pressures in soft sand but without a compressor you'll baulk at the idea. COMMS: If you have a problem you can't fix yourself and you're in a remote place then either
HF radio and/or EPIRB is a potential life saver. HF is expensive but gives you access to RFDS and VKS 737 (Aus National 4WD Radio Netw). With VKS 737 you can regularly report your progress, get road reports, talk to others in the vicinity and get messages to and from loved ones. I would also recommend CB's (both UHF and 27 Meg) so you can team up and talk to others you meet along the way. WEIGHT: The down-side to taking lots of gear is the extra weight which will shorten your range and put extra stresses on everything especially tyres. Some sugestions: a)Replace the second spare wheel with a spare case only - know how to remove and re-fit a case if needed. Consider split rims, which are dead simple to fit, and 7.50R16 tyres, which are easy to get in the outback. b)Replace your Engel fridge with a good quality esky of the same capacity. With 4 large freezer blocks (2 in the esky, 2 in the freezer, swap daily) we have no problems keeping things cool and there is less weight and less drain on batteries. Remember your spare wheel carrier are made of steel and is very heavy. Leave it behind if at all possible - put the spare case on the roof. This also improves access to the tail
gate. Have a guess how heavy is your vehicle fully laden - then weigh it - a mate did this and his L/C Tray Back went over 3.5 Tonnes compared with less than 2 tonnes curb weight? RANGE: 95 litres is not alot of fuel in outback conditions with a heavy vehicle. As a rule of thumb we carry 50% more fuel than needed to get to the next refuelling point. This means that we can get 3/4 of the way and if the road is impassible we can still get back to the previous refuelling point. This sounds a bit like a lecture but I know you'll take it in the spirit it is given - have a great trip.
2598
Follow Up By: Dennisn - Wednesday, Apr 03, 2002 at 00:00
Gordon, A great reply which I think everybody reading it will benefit from. One point on using HF Radio/EPIRB if you find yourself in a problem you cant fix yourself. The EPIRB must only be used in a genuine LIFE THREATENING EMERGENCY - as opposed to the
HF radio which you could use to get help with a broken down vehicle or similar situation. The use of EPIRBs is the same as an SOS or Mayday call on normal radio Distress Frequencies - only for LIFE THREATENING EMERGENCIES. Regards
966
Reply By: Mal Try - Wednesday, Apr 03, 2002 at 00:00
Jeff, the most important thing is a good woman. You must be compatable living that close together for that long. It's an idea to try some 6 to 8 week trips to make sure everything works. The next most important thing for safety and peace of mind is a
HF radio. If something happens you can always raise someone. As everyone can hear radio transmissions (as opposed to sat-phone) there may be someone over the next
hill who hears your call for help and can assist you in minutes. VKS 737 radio will know if there is anyone close and can ask them to assist you. Make sure that everyone in your party knows how to use the radio and everything else. If you have injured yourself and you get a flat everyone needs to know what to do. Anyway, it might be her turn! The other thing that people forget about is the boat trailer especially if you are going to be carrying gear in the boat. It should have the same wheels and tyres as your Disco and preferably springs and hangers off an old L/cruiser or Patrol with a few leaves removed. It may look funny but it will get you there. The drawbar and mudguards may also need reinforcing. I hope I havent been too simplistic-just trying to help. Have a great trip. Mal.
2599
Follow Up By: Gordon - Wednesday, Apr 03, 2002 at 00:00
Jeff,I agree with all that Mal said. I didn't consider the trailer in my earlier reply. Some other things about trailers: (i) The outback is littered with broken trailers that were too light for the hard pounding they get on rough roads, don't let yours become one of them. (ii) Trailers are a pain in genuine 4WD country because if you fail in your first attempt to get through or over an obstacle (eg.bog,
sand dune, slippery slope) reversing from that position is nearly always impossible without jack-knifing. Instead of simply reversing and having another go, you will be looking at a)forward recovery (tow, snatch or winch) or b)unhitch the trailer man-handle it out of the way, reverse the Disco, winch the trailer out, re-hitch. Either way (forward or back) it will take a while unless you travel with another "willing" vehicle in front to tow you through. (iii) You will also need a substantial stone guard to protect the dingy on rough roads. POSSIBLE SOLUTION: A way to avoid all these problems is to put the dingy on the roof (using rollers on the roof rack and your winch to get it up and down). I have seen others with this set-up but can't comment on its effectiveness. Hopefully someone else will advise. Cheers.
967
Follow Up By: Jeff - Wednesday, Apr 03, 2002 at 00:00
Thanks Mal for your reply.. First of all, I have definatly got myself a good woman...so good I married her. I spent 5 weeks touring Coral Bay/
Steep Point camping and fishing whilst my wife was on OUR honeymoon...and she loved it! All other info has been taken in and is much apprieciated.
Thanks again to all who responed
Jeff and "the good woman" Kelly
970
Reply By: Mark - Wednesday, Apr 03, 2002 at 00:00
Jeff,
Aside from the accesories required for this type of trip the condition of the vehicle is equally as important. If yours is a TDI make sure you have had the timing gear mod kit done and the belt has not exceeded 80,000k. Broken timing belts are a known problem on TDI 300's and mod's were carried out to the timing gears to stop the belt wondering off and rubbing against the timing cover. Some models may also require a new timing cover depending on the VIN number (I can dig them out of you need the VIN numbers of affected vehicles). A broken belt and at best bent pushrods could be a major inconvienience in the bush and put a big dent in your budget. How did you get 235/85 tyres to fit ?? did you get the tin snips out!
Mark
2605
Reply By: jeff - Thursday, Apr 04, 2002 at 00:00
Thanks Mark.. Yes, not only tin snips but electic jigsaw. Took about 1" out of guard allround. Have a mate that's a bodybuilder, so he did most of the work whilst I opened the coldies. Disco is a 3.9 V8. serviced every 5000km by Robson Bro's over here in
Perth.
Thanks for the
feedback
Jeff
2629
