LPG 9kg POL to 3/8" extension hose availability?
Submitted: Thursday, Nov 10, 2011 at 09:20
Sam39
Hi, I am wanting to extend the length of my LPG hose by 3 metres from my LPG 9Kg POL gas bottle to my low pressure 3/8" Coleman cooker, its currently about 50cm long. I have managed to find a POL to 3/8" adapter so have sorted the initially connectivity issue and tested it and it seems to work fine.
Normally I use a smaller gas bottle and just move it round but we are going on a longer trip so we wanted to take a larger gas bottle. The problem is that the mount point in the trailer for the gas bottle is about 3 metres from the cooking area when the kitchen area is extended from the camper trailer. I was hoping to add a 3 meter hose with a 3/8” or POL male (either would would as I have the adapter) to 3/8" female brass cone connector on the existing 50cm long hose.
I suspect these do not existing for some reason or there might be another connection method I am not aware of. Any assistance would be greatly appreciated, thanks in advance.
Reply By: ozjohn0 - Thursday, Nov 10, 2011 at 09:48
The longest I've seen are braided ones at camping stores etc, but they're only around 1.5 - 2 meteres.
Ozjohn.
469617
Reply By: Ozrover - Thursday, Nov 10, 2011 at 10:09
Sam,
I had a gas hose extended a few years ago by a fellow in a weling supply
shop (Weldquip from memory) in Leumeah sw
Sydney.
You should be able to have one made up to the length that you require by any gas supply qutlet.
469618
Reply By: workhorse - Thursday, Nov 10, 2011 at 12:59
Bunnings have 1.8mtre (I'm pretty sure) and other lengths braided ss hoses. You can get a connector from a plumbing supply and fit the two together.
469635
Follow Up By: Member - Phil 'n Jill (WA) - Thursday, Nov 10, 2011 at 14:06
Hi guys
Might pay to
check legality on 'joins'.
We have 3 metre lengths in WA, but I have a feeling you can't join or extend beyond that - safety issues involved I guess.
Regards - Phil
744063
Reply By: Kimba10 - Thursday, Nov 10, 2011 at 15:34
3 metres from bunnings. Got one for gas heater at
home but this is natural gas, not sure if that will make a difference for availability ??...............
469647
Follow Up By: Member - Phil 'n Jill (WA) - Thursday, Nov 10, 2011 at 18:09
Prolbably not Bunnings - 3metre hoses available at some Kleenheat gas appliance stores - Phil
744080
Follow Up By: Kimba10 - Thursday, Nov 10, 2011 at 20:51
Your probably wright, it was 10 years ago lol. ...............
744115
Reply By: PARSO - Friday, Nov 11, 2011 at 17:41
Hey Sam.
Try your local Barbeques Galore
shop first. I wish I had...would have saved several hours ratting through Bunnings, and a number of other stores where my enquiries were met with little more than blank looks.
Hope this helps.
PARSO
469780
Reply By: Sam39 - Friday, Nov 11, 2011 at 18:09
Thanks all for the replies, it certainly seems to be a hard question to answer.
I gave up after the first few shops just gave me blank looks.
The other day I rang a mate who is a plumber and he said he will sort for me in the near future. Once i get a result or understand the issue better I will post something here.
469783
