Mitsubishi Challenger
Submitted: Friday, Dec 05, 2003 at 09:01
Paul_D
Recently bought a 2000 model challenger, at 100km/hr there is a vibration up through the steering wheel. The service manager at the dealership where I bought the car has done a wheel balance that hasn't corrected the problem. I asked for a wheel alignment but was told that probably would not fix the problem.
Reply By: Well 55 - Friday, Dec 05, 2003 at 09:26
Go for an alignment and 'on car' ballance.
The alignment to make sure the wheels are pointing in the same direction, and on car ballance will duplicate on road driving.
39499
Reply By: ron1 - Friday, Dec 05, 2003 at 11:32
also
check ur tail shaft , and ware in any steering joints
ron
39506
Reply By: Eric Experience. - Friday, Dec 05, 2003 at 22:25
Paul.
The most likely cause is a delaminated tyre, swap the front to back or jack up the front wheel under the wishbone so that the tyre is 1 mm of the ground then spin the wheel by hand if the tyre is delaminating the tyre will touch the ground at the problem spot. Eric.
39544
