tare of 1983 Viscount
Submitted: Tuesday, Oct 11, 2011 at 11:38
STAN C1
Hi does anyone know the tare weight of an 1983 Viscount aerolite,
cant seem to get any info anywhere's, there being out of production.
Reply By: snoopyone - Tuesday, Oct 11, 2011 at 12:30
Some idea of the size may be a help. Otherwise like finding a needle in the dark.
467330
Follow Up By: STAN C1 - Tuesday, Oct 11, 2011 at 13:56
yere you right,(it would help) its 15ft , and tug is an Xtrail
741435
Reply By: disco driver - Tuesday, Oct 11, 2011 at 13:07
Stan,
My 82 Viscount Grand Tourer 16ft says "Tare 800kg" on it's rego papers.
That doesn't mean that it's totally accurate, but is a start.
The Aerolite is quite a bit lighter but I'm not prepared to guess by how much.
The safest and easiest way is to take it to a public weighbridge and weigh it. Keep the weighbridge docket with your other papers relating to the van.
Hope this helps
Disco.
467332
Follow Up By: STAN C1 - Tuesday, Oct 11, 2011 at 13:58
Tks for that Disco, I thought
mine would have been around the 800kg, its 15ft in length . I'll have to look around to find a weighbridge somewhere's in Gippsland
vic..
741436
Follow Up By: Member - MUZBRY(Vic) - Tuesday, Oct 11, 2011 at 15:19
Gday Stan
If you google Public weigh bridges in Victoria, there is a list of all the address
741451
Follow Up By: STAN C1 - Wednesday, Oct 12, 2011 at 12:16
Thankyou Muzbry, will be getting on to it now
Stan
741550
Follow Up By: Member - MUZBRY(Vic) - Wednesday, Oct 12, 2011 at 13:24
Gday
Pleasure Stan
741554
Follow Up By: STAN C1 - Wednesday, Oct 12, 2011 at 14:34
hi Muzbry & Disco,
Looked up weighbridges and found one in my area (thks Muza)
Disco, looked at my rego sticker and the tare says 940kg havig only just purchased the van havent got the rego papers yet, due for rego in Feb 2012.
stan
741563
Follow Up By: Member - MUZBRY(Vic) - Wednesday, Oct 12, 2011 at 15:00
Gday Stan
It's all to easy Stan....
741565
Follow Up By: STAN C1 - Wednesday, Oct 12, 2011 at 15:17
Muzbry,
Photo's of you aren't far from where I live.
741568
Follow Up By: Member - MUZBRY(Vic) - Wednesday, Oct 12, 2011 at 15:39
Gday Stan
I'll let you know next time we come up that way...
741570
Reply By: ozjohn0 - Thursday, Oct 13, 2011 at 11:28
from memory the Tare was around 940Kg and 960Kg with two gas cylinders, but best to get it weighed to be on the safe side.
Remember to empty the water tanks, and have empty gas cylinder(s) or subtract the weight of any LPG in the cylinder(s).
Cheers, ozjohn.
467510
Follow Up By: STAN C1 - Thursday, Oct 13, 2011 at 12:14
thks for that oz
john, the
water tank is empty and have only one gas cylinder for van it's off at present , might as
well leave it off.... Ive just put a new coupling on so i will be able to disengage brake when reversing...
cheers Stan C1
741650
Follow Up By: ozjohn0 - Friday, Oct 14, 2011 at 13:42
Stan,
leave the Gas bottle on Mate, just subtract the gas weight for the weigh
bridge figure.
I.e. a full cylinder will have 8 - 9Kg of LPG.
Cheers, ozjohn.
741732
Follow Up By: STAN C1 - Friday, Oct 14, 2011 at 14:40
ozjohn0 right thanks for that mate, will put it on before weighing...
good to know all of this info...
stan
741736
