T Belt
Submitted: Saturday, Oct 08, 2011 at 19:30
Member - Noel C (NSW)
My 2004 100 series auto TD is due to have its T belt changed. What would you guys recommend I get serviced at the same time??
Reply By: vk1dx - Saturday, Oct 08, 2011 at 19:34
Just what the book says. Unless someone else has a better idea.
PS: I assume the "T" belt is the timing belt. Sorry but I hate all these acronyms and abbreviations.
467130
Follow Up By: Member - Noel C (NSW) - Saturday, Oct 08, 2011 at 19:42
Yep
741224
Follow Up By: Member - MUZBRY(Vic) - Saturday, Oct 08, 2011 at 20:09
Gday Phil
I don't like diffs that" blow up" and engines that "blow up" and the odd gear box that "blows up" . There needs to be a better explanation for the problems that people have . Being an old powder monkey, I know what blown up means.
741225
Follow Up By: fisho64 - Saturday, Oct 08, 2011 at 20:27
"blown up" is used by clowns who dont know what they are talking about unfortunately.
Regarding your 150K service-Toyota no longer requires the injector lines changing.
The timing belt is dead easy to change yourself, as it doesnt go round the crankshaft, 1 hr job.
BUT I got Toyota to do anyway as the tensioner is about $250 also and if they do it you get 100K 3 yr warranty on parts and labour, plus they sold me the tensioner at trade so it was a no-brainer for me.
741228
Follow Up By: vk1dx - Saturday, Oct 08, 2011 at 20:30
Muz
I don't get you. What are you getting at?
741229
Follow Up By: Member - MUZBRY(Vic) - Saturday, Oct 08, 2011 at 20:42
Gday
Same as you old son. Abbreviations and acronyms and explanations that are non descriptive , just general, that no one understands,
well I don't understand.
Acronims are used by people that are to lazy to write the full word.
741235
Follow Up By: kidsandall - Saturday, Oct 08, 2011 at 20:44
Muzbry, who said anything about blowing anything up???? What do you mean?????????
Josh
741236
Follow Up By: Member - Noel C (NSW) - Saturday, Oct 08, 2011 at 20:45
OMG
741238
Follow Up By: SteveL - Saturday, Oct 08, 2011 at 20:50
He just "blew up" about "blowing up".
741239
Follow Up By: Member - MUZBRY(Vic) - Saturday, Oct 08, 2011 at 20:51
Gday
Do you know what i find sad ? People sitting
home on Saturday night trying to wind me up. It wont work Josh. I am unwinderbull.
741240
Follow Up By: vk1dx - Saturday, Oct 08, 2011 at 21:12
That's blown it now. I may as
well go and "blow the top off one".
Catchya
741242
Follow Up By: Member - MUZBRY(Vic) - Saturday, Oct 08, 2011 at 21:16
Gday
Have one for me Phil .
Enjoy the night
741244
Follow Up By: Bigfish - Saturday, Oct 08, 2011 at 21:39
Muzbry,,,,I think you best take another valium and lie down...If you didnt understand that a"t belt" was short for timing belt then best you enrol in a very basic mechanical course. Who mentioned "blown up"...yes I have a powder monkeys ticket yet I dont think anyone mentioned "blown up".
Put your glass of sherry down and read the query.
Enjoy the evening.
741245
Follow Up By: Member - MUZBRY(Vic) - Saturday, Oct 08, 2011 at 21:48
Thanks for the offer of a valium and a lie down.
I was agreeing with Phil who did not like acronims and abbreviations. I don't like people who can't put the whole word down . Ihave yet to see a diff of gear box "blow up" they might break or wear out , do a bearing or a pinion seal,run out of oil, but blow up, i think not.
So now i will have the valium and the lay down.
Thanks Bigfish....enjoy your evening.
741246
Follow Up By: GimmeeIsolation - Saturday, Oct 08, 2011 at 21:49
This post has been read by the moderation team and has been moderated due to a breach of The Foul Language Rule .
Forum Moderation Team
741247
Follow Up By: kidsandall - Saturday, Oct 08, 2011 at 23:24
Geez Muzbry, I was actually asking a question as I had no Idea what you meant by talking about "blown up". I now understand. I was not trying to "wind you up. The OP (original poster) never mentioned gear boxes, diffs or anything blowing up. As I said, just trying to work out what you meant.
Josh
741251
Reply By: Member - Phil G (SA) - Saturday, Oct 08, 2011 at 22:25
I've got the same motor. To keep things reliable, for the next 150,000k, I also did:
- Timing belt tensioner and bearing
- fan and A/C belts,
- new radiator hoses
- new thermostat
- replaced water pump (easily accessible while timing belt is off)
- removed alternator and replaced brushes
- removed radiator and cleaned out the fins of mud and grass
- flushed and replaced power steering fluid
- adjusted valve clearances
I used only Toyota parts and did the work myself. I figure if I'm going to keep the vehicle I want it to be reliable, so replaced the bits that are likely to fail over the next 150,000k. They are all cheap parts, and cheap insurance, and once you remove the radiator all these jobs are easy. Some of the old parts are now carried as spares.
467141
Follow Up By: fisho64 - Sunday, Oct 09, 2011 at 00:22
A question-how did you drain and flush the power steering? I cant find anywhere on either of my toyotas (1hdj100 and KZN165) that will easily accomplish it, and the manual is suitably vague?
741256
Follow Up By: Member - Phil G (SA) - Sunday, Oct 09, 2011 at 00:44
I drained and refilled the reservoir a few times by using a syringe and tubing. I ran the vehicle in between to circulate the fluid. I'm sure there are better ways of doing it but this is the least messy that I know.
It's not listed as a service item and it seems like it only ever gets changed when the power steering pump starts leaking and needs an overhaul. I know one 4wd mechanic who changes his every 2 years.
741257
Follow Up By: Bigfish - Sunday, Oct 09, 2011 at 08:09
Cheap insurance AND you get to know your car, you know what has and hasnt been replaced, you saved a heap in money, you now have peace of mind on a trip, you also know what to do if stuck in the bush so I,d say that you come out a winner. I think if more people did some of the minor work on their vehicles there would be a lot less stranded people and with the money saved a few kilometers or sightseeing.
cheer
741262
Follow Up By: obee1212 - Sunday, Oct 09, 2011 at 09:28
remove the fluid our hose and start the motor wiggle the steering wheel and the old fluid ppumps out. refill reservoir wiggle and top up. After five years i think its time to do it again along with the big serice.
741264
Reply By: philldeb - Saturday, Oct 08, 2011 at 23:19
I would do the water pump as
well
467145
Reply By: snoopyone - Sunday, Oct 09, 2011 at 09:19
The price posted for the tensioner is waaaaaaaaaaaaaay more than I paid
The whole job with a tensioner and an idler and belt was around $300 The idler was about $50 and the tensioner was about $90 from memory.
I had
mine done by Toyota at the 140,000 service and all up cost about $1200 foir the lot (Big service and belts)
467156
Follow Up By: Member - Phil G (SA) - Sunday, Oct 09, 2011 at 19:25
Yep, genuine tensioner from Toyota cost me about $100 last year.
741313
Follow Up By: mike39 - Sunday, Oct 09, 2011 at 19:41
Not sure if the parts you are referring to are these, but this week bought for '97/ hzj 75series:
Fan belts (2), timing belt, tensioner idler kit, from Toyota, total cost $166.00 (trade price with ABN)
mike
741316
Follow Up By: snoopyone - Sunday, Oct 09, 2011 at 19:48
No for a 1HD -FTE
741318
Reply By: Member - Richard W (NSW) - Monday, Oct 10, 2011 at 06:57
Fisho64,
quote 'Regarding your 150K service-Toyota no longer requires the injector lines changing.'
Was this notified to dealers as I had my mechanic go by the book which included the injector lines and this was done in June 09 at the 150K service.
Noel,
I'm assuming you have the have the 1HD-FTE motor the same as mine.
As well as a general service I had the Timing Belt and Injector Lines done and they also found the water pump was leaking so this was replaced as well.
467229
