Who has done +500000 km in their Land Cruiser (1HZ)?
Submitted: Saturday, Sep 17, 2011 at 15:10
bikemaniac
This discussion is addressed to those who have done more than 500000 kms in their Land Cruisers and still being the first owner.
Soon I will be getting my brand new Land Cruiser with the 1HZ engine. It should last at least 500000 kms. I have four questions:
1. How did you break in your engine from day 1 (if you still remember)? Did you drive it hard, soft, high load, low load?
2. How often do you do oil changes?
3. What type of oil do you use? It is my impression that Australians still go by mineral oil with frequent changes and Europeans with fully synthetic with longer intervals.
4. How often do you do filter changes?
Lucas
Reply By: bikemaniac - Saturday, Sep 17, 2011 at 15:17
Forgot the 5th question:
5. What is your oil consumption right now (@ how many kms)?
Lucas
465278
Reply By: willawa - Saturday, Sep 17, 2011 at 20:59
Lucas
Why don't you ask your Toyota dealer?
willawa
465293
Reply By: Member - Doug T (NT) - Sunday, Sep 18, 2011 at 04:19
Where do you find brand New Land Cruisers with the 1HZ Engine these days....????
465327
Follow Up By: Rockape - Sunday, Sep 18, 2011 at 06:22
Doug,
South Africa, it should be run in by the time it's driven across the Indian Ocean. LOL.
RA.
739340
Reply By: get outmore - Sunday, Sep 18, 2011 at 06:39
yet another person pre occupied with engine life
theres alot more to a 4by than the donk generally after about 300k they start needing a fair bit of maintance sooner if used hard and later if not often the cost of a motor is cheap compared to what gets spent on everything else
465331
Follow Up By: Michael ( Moss Vale NSW) - Sunday, Sep 18, 2011 at 10:49
Ask Doug T about his engine K's and how much he has spent on it!! Michael
| Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.Member My Profile My Blog Send Message |
739365
Reply By: Member - Alastair D (NSW) - Sunday, Sep 18, 2011 at 17:51
Lucas,
My 1995 1Hz troopy has done just on 400,000 so it is a youngster.
1. - I did not buy it new but I know that it was worked hard on a
farm which would have involved quite a bit of short haul stop start stuff.
2. I change oil every 5,000 as did the original owner
3. I use Penrite Diesel which is a non-synthetic. There is a synthetic version which is use in my 100 series. I would assume that your new engine would have the appropriate material used for the seals etc so that you can use synthetic without a problem. It causes major issues in older vehicles causing seals to harden and fail. The handbook will advise.
4. I change the filter with every oil change. I use genuine ones which cost about $30 ea.
5. My fuel consumption is on trips varies from 9 to 13 L/100k depending on conditions, but typically I get around 11. I do not tow with this vehicle - for that I use the 100 series with the factory turbo.
Oil consumption is about 1/2L between changes with up to 1L if the weather is very hot and I am working it hard. This has not changed over the last 200K and I don't worry as it does not blow noticeable smoke.
The cylinder compressions were tested about 100K ago and all were ok. I am happy this engine will keep going for a long time yet.
465390
Follow Up By: bikemaniac - Sunday, Sep 18, 2011 at 18:00
Thanks for your indepth answer. Exactly what I was looking for.
Lucas
739415
