Tuesday, Sep 13, 2011 at 17:09
thanks for that info Robin!! from your & Allan's comments, and reading the info on the
forum I have decided to keep the microwave only for when I am at a powered site. Probably only 20% of the time. Otherwise rely on the little gas BBQ.
My trips will be mostly 3 day long weekends when I go to kitesurfing events and the odd 5-7 day trip. I already have the deep cycle AGM 150AH battery so would like to incorporate that. I can get another of these far below retail ($220, Eaton brand) from a friend in the boat building industry.
I am now thinking
solar power would be a good idea although the cost and the fact it was not 100% reliable (in case of a run of cloudy days) had deterred me initially. I tend to travel based on a good forecast so usually when it's sunny! and I probably wont ever go more than a few days without access to power so am considering making my system totally independent from the main vehicle battery (easier to wire, less costly to install and simpler to maintain?)
Another friend has 2 x 120 watt solar panels almost new that they no longer need and may give me (a barter arrangement for some stuff i no longer need).
I need to do the sums, but am thinking now of a system like:
1. 2 x 150AH deep cycle batteries not connected to the main vehicle battery
2. 2 x 120 watt solar panels with a charge regulator recharging the batteries
3. voltage meter on the battery bank with some sort of automatic cutoff when they drop below 50%
4. backup electric battery charger to be connected manually if need be (my dad has a few of these because he is a caravaner so would not have to purchase immediately) hopefully not necessary on weekend trips
thank you all for your patience & help.
738842
