Clutch/Gearbox repair shop-Cairns
Submitted: Wednesday, Sep 07, 2011 at 13:03
ThreadID: 88884 Views:2885 Replies:3 FollowUps:4
Anyone recommend a good 4x4 Clutch/Gearbox repair mob around Cairns
Cozzie
Reply By: new boy - Wednesday, Sep 07, 2011 at 16:56
hi Cozzie
This was done or a similar request in July so look at thread 87381 will give you some options
AnswerID: 464444
Follow Up By: Member - Cozzie Toodyay (WA) - Thursday, Sep 08, 2011 at 06:58
Thanks new boy
FollowupID: 738429
Reply By: dazren - Wednesday, Sep 07, 2011 at 18:20
Gidday Cozzie, Hope it's not to serious ?? is your car still under warranty ??? I have just bought a Colarado [ factory Duel/Fuel Auto ] so do not like to see threads like this, Hope you find a good mechanic, and it does not hit your pocket to much, Good Luck dazren
AnswerID: 464450
Follow Up By: Member - Cozzie Toodyay (WA) - Thursday, Sep 08, 2011 at 07:03
Hi Dazren, it's starting to sound serious, grinding sort of noise when travelling slow in first, crunches into second and you need muscles in ya poo to get it into 5th when cold, grinding noise is worse when cold also.
Cozzie
FollowupID: 738430
Follow Up By: dazren - Thursday, Sep 08, 2011 at 19:41
Geez cosie. you have had a bad run, where were you when you hit the chinaman ?? [ oops is that politicaly correct nowadays ] from what i read on these forums, gearboxes and clutches, are not like the robust, reliable ones we had in the old day's, being a 2008 model, isn't your colarado still basically the same as the Isuzu if so i thought they had a better reputation than that. especially with your injectors going as well ??. Hope your run of bad luck has come to an end, good luck dazren
FollowupID: 738485
Reply By: Dave B ( BHQ NSW) - Wednesday, Sep 07, 2011 at 19:25
Gee Cozzie, your not having a good run.
I am a bit far away to know where to send you for your geabox.
Dave
'Wouldn't be dead for quids'
AnswerID: 464458
Follow Up By: Member - Cozzie Toodyay (WA) - Thursday, Sep 08, 2011 at 07:12
Your not wrong Dave, all started when we hit the NT had to get injectors replaced in Darwin, up in Gove I ended up with a perforated ear drum, then the stub axel came a drift on the camper due to dodge welds and caused the thing to roll, the insurance has written it off, now the gearbox is giving me grief, like Ned said "Such is Life" will put me violin away now
Cozzie
FollowupID: 738433
