How to remove clear contact adhesive from the sides of my Prado
Submitted: Sunday, Sep 04, 2011 at 21:17
Member - mickmci
Members. This saga started when i purchased new rear view mirrors so I could see past my caravan, The mirrors had straps which held the mirror steady by hooking onto the bottom of the respective driver and front passenger doors. Unfortunately the straps contacted the duco on the door and I was worried that over time dust & road grime etc that the duco would be damaged. I heard that by using clear contact adhesive yes the same stuff that kids use to cover their school books and removing it by use of the heat from a hair dryer and pulling it off that all would be ok.
Well all things not being equal two nearly three years have now passed and I went to remove same finding out that it wont come off as the grit etc has warn it so thin that it just tears. Suggestions please re an easier way to get this stuff off. The duco seems fine. Regards Mick
Reply By: lancie49 - Sunday, Sep 04, 2011 at 21:26
Eucalyptus oil ?
Disolve-It ?
Petrol ?
464217
Follow Up By: SA Bob - Monday, Sep 05, 2011 at 02:14
2nd Eucalyptus oil
738122
Follow Up By: Jarse - Monday, Sep 05, 2011 at 15:49
That or Ti-tree oil.
Under no circumstances use acetone as somebody recommended! That will strip your paint.
738157
Reply By: Member - Wayne B (NSW) - Sunday, Sep 04, 2011 at 21:27
You may need to use some form of accidtone , mineral turps, metho or the like
I tried all of them to remove stick on tinting from the door glass, a real pain but it eventually dissolved the adhesive and while not 100% I can at least now see through the glass.
Have a talk to a spray painter they should be able to put you on the right track.
Wayne B
464218
Follow Up By: CSeaJay - Monday, Sep 05, 2011 at 17:50
NO!
With due respect - do not do this you will damage the paint.
Eucalyptus oil works a treat
738167
Follow Up By: Member - Wayne B (NSW) - Monday, Sep 05, 2011 at 21:26
CSeayjay
Fair comment. They can damage the paint if not used sparingly and left on the surface for too long.
Wayne
738207
Reply By: Member - Jason B (NSW) - Sunday, Sep 04, 2011 at 21:31
Hey mate. Try things the things that are least likely to affect your paint first, Try Kerosene as it is oil based and will not harm the paint. Also WD40 is gold for dissolving adhesives.
Jas
464219
Reply By: Stan2.8D - Sunday, Sep 04, 2011 at 22:10
When removing window tints which are similar to contact, I found the only two methods which worked were:
Engine degreaser
Steam
If you can borrow a wallpaper remover (steam type) that would be excellent or failing that any steam mop etc.
I have found engine degreaser to be better than WD40, turps, metho etc on several occasions, for removing glue/glued plastic.
464223
Follow Up By: lancie49 - Sunday, Sep 04, 2011 at 22:19
Just stayning with the window tint for a moment.
I've not tried it, but apparently if you put a sheet of wet newspaper on the tint and keep it wet for an hour or so, the tint lifts off easily. I'll try to get that confirmed.
I doubt that will help Mick with his problem, but hey, may be worth a try.
738117
Follow Up By: Member - Wayne B (NSW) - Monday, Sep 05, 2011 at 21:21
Thanks for the tips on removing window tint
Wayne
738206
Reply By: Maaate - Monday, Sep 05, 2011 at 05:55
I have found the following works with removing old rego labels:
Wet some glad wrap (cling film) and spread it over the label. Try to keep as much
water as possible between the cling film and the label. After a few minutes, carefully peel the old label off. Any remaining adhesive can be remove with a damp cloth. Depending on how large and how thin your contact is, this may work.
464227
Reply By: ss--ss - Monday, Sep 05, 2011 at 05:56
G'day I would try a hairdryer, this is also best way to get window tints off.. Start in the corner & see if I comes off...
464228
Reply By: Sand Man (SA) - Monday, Sep 05, 2011 at 07:23
I'll second De-Solve-It.
This product will not harm the paintwork..
As the contact adhesive is not porous, the de-solve-it (or any other liquid product) won't penetrate so you will need to start at an upper edge, let the liquid seem in to the upper edge and gradually work down.
You could also try a hair dryer or heat gun to remove the bulk of the contact and backing, then de-solve-it, or eucalyptus oil to clean up the residue adhesive.
464232
Reply By: Notso - Monday, Sep 05, 2011 at 08:20
For future reference there is a product that Repco sells specifically for the job of protecting paint work. It is supposed to be easily removable. Hope so I've done
mine with it???
464233
Follow Up By: TheMightyMoose - Monday, Sep 05, 2011 at 12:49
And that product would be called???
738142
Follow Up By: Notso - Monday, Sep 05, 2011 at 13:23
Yeah, I'm getting old and can't remember, just ask in any Repco Store.
It is a clear plastic film, fairly thick really, probably not what you'd call a film!!
738144
Follow Up By: http://www.ExplorOz. - Monday, Sep 05, 2011 at 15:55
In the future if you want use protection against abrasion ,I have used clear plastic film which stick to any smooth surface ,and is available in different thickness from Clark's Rubber.I used on my car door,to protect from magnet bracket of towing mirrors,four couple of years,no damage to the duco ,the only thing is you have to clean up when you take your mirrors off,because it stick temporally only.Very good stuff.
738160
Follow Up By: lancie49 - Monday, Sep 05, 2011 at 18:10
I've got that product in stock if anyone's interested in finding out more about it.
It is self adhesive, but with the added advantage of being easily removable.
738170
Follow Up By: Member - Ed C (QLD) - Monday, Sep 05, 2011 at 21:27
I think this be it (??)
Altrex Body Skinz
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
738209
Reply By: Dereki - Monday, Sep 05, 2011 at 08:27
I use wd40... works for me. No idea if its bad for the paint, but I haven't noticed any issues.
There is special protection film you can get from auto stores for protection. Its much thicker and is easier to get off.
D
464235
Reply By: snoopyone - Monday, Sep 05, 2011 at 09:12
I have Ozishield protective film on my two cars and their instructions for removal say to soften it with a hairdryer on LOW heat andpull it off at 180Deg
That is back over itself.
Make sure surface is warmed all over as it could pull paint off if area has been repainted
Keep heat on it while pulling it
Any remaining adhesive can be removed with METHS
464239
Reply By: Shaker - Monday, Sep 05, 2011 at 09:29
Try Prepsol.
464240
Reply By: Member - barry F (NSW) - Monday, Sep 05, 2011 at 09:35
Hi Macka, many suggestions so far so hopefully by now you have the contact removed without damage to your Duco.
For your info Scotch 3M market a product specifically designed for the removal of adhesives. It is called "700 adhesive cleaner & solvent", it is an excellent product but not cheap at about $25 for a 350g pressure pak container. I'm not sure but maybe it is available in smaller size container.
Good luck
464241
Reply By: edwin - Monday, Sep 05, 2011 at 11:40
hi mick, the pros use a thing called a pin stripe wheel for removing pin stripes and vinyl stickers and window tint, its a rubber wheel that goes on the end of a drill and it rubs the stuff off
the missus banged the back of the colorado and i got hold of a dmax tray which had large izuzu sticker on the tailgate, after using everyones methods above nothing worked, i rang the local window tinter for help and he sold me the wheel for $10 and had it off in 10 minutes,
can get them from auto paint stores or ask your local parts store
let us know how you go
ed
464249
Follow Up By: snoopyone - Monday, Sep 05, 2011 at 14:20
The stuff he is probably trying to get off is a .2mm sheet of plastic which is quite strong and would be resistant to things that take decals off.
I have just done the door sills on 2 cars with it and its quite surprising how it can be stretched without tearing.
The instructions from Ozishield should do it although it can get brittle after a long time in the sun.
Se it here www.ozishield.com.au
738150
Reply By: Member - Stanley D - Tuesday, Sep 06, 2011 at 16:56
Another good way to remove adhesive remain is to use Mr Sheen spray and a white cloth (old tee shirt). It will take the goo off book covers, DVD covers, and the like. Caution on Painted surfaces- just be sure that you won't be painting any time soon as the silicone may prevent successful repaints. Hope this helps
regards,
Stanley
464364
