Tuesday, Aug 30, 2011 at 06:45
Tony Z
I have a 120 watt folding momocrystaline panel, but could not figure anything out, at first, because I was pulling up, setting up
camp, putting out the panels, then attempting to measuring panel output.
Der me,.... Battery fully charged after driving most of the day,therefore would not accept from panel....conclusion, panelmworkinf fine
Still not happy, as panel only showing a series of blinking lights.
But wait, we have Technology....
Enter the Powertec MP3129 controller, hooked it into the system, disconnected the $10 controller, that came with the panels.
It has a digital display, and cycles between, PV Voltage, Battery Voltage, State of charge, Amps being delivered to Battery, and a heap of other things thet confuse me a little
Now I know exactly what the panels are doing, and when working, the panels (most I have seen from controller) can pump in 3.5 amps, and run my Engel, and keep the battery topped up.
Works a treat, amd my knowlege of solar charging has gone up from nill, to just enuf to know what is going on, sort of
Bucky
463836
Follow Up By: Member - Tony Z (NSW) - Tuesday, Aug 30, 2011 at 15:46
Bucky,
I think I will go and buy a DC-DC charger that has an MPPT controller in it ( Redarc / Ctek ) or similar to up the power from the tug while travelling around
Thanks for the info
737746
Follow Up By: S Paul - VIC - Wednesday, Aug 31, 2011 at 09:27
Bucky ,
Is there a reason why your 120W panel is only putting out 3.5A ??
quote"Now I know exactly what the panels are doing, and when working, the panels (most I have seen from controller) can pump in 3.5 amps, and run my Engel, and keep the battery topped up."
You should be getting close to 6 Amps peak performance from any old regulator .
Steve
737809
Follow Up By: Member - Bucky - Wednesday, Aug 31, 2011 at 15:33
Steve
The only reason I can think of is the battery and the controller, have conspired to do.
Kinda makes sence to me, that the battery state of charge is monitored, by the controller, and then adjusted so as not to boil the battery.
Cheers Bucky
737838
Follow Up By: Member - Tony Z (NSW) - Wednesday, Aug 31, 2011 at 20:27
Thanks all of you for your help, Now I will be able to start to work things out
737860
