BA door alarm problem
Submitted: Thursday, Aug 25, 2011 at 12:22
john l7
I have a 2003 BA wagon and have a really annoying intermittent problem. Occasionally the door alarm goes off , the inside light and dash icon come on. It beeps a couple of times, the icon on the dash stays on until i put my foot on the brake and it goes way, only to start beeping again when i release the brake . It is weird , and then just as strangely it goes away, not to happen for another few days when it comes back. ITS AS IF THE CAR THINKS THE DOORS ARE OPEN when they are definitely not.I have checked the boot and door locks (but not the actuators) . Any ideas ?
JOHN, Coffs.
Reply By: Member - Allan F (Gold Coast) - Thursday, Aug 25, 2011 at 17:39
We just fixed a BA with a similar problem at work today. They have a switch in the door lock assembly which tells the BCM the state of that door. The fix is to replace the offending lock. If that doesn't fix the problem then the BCM is faulty. Also
check all the body earths as Fords are susceptible to earth problems. Hope this helps
Cheers Allan
463514
Reply By: john l7 - Thursday, Aug 25, 2011 at 17:45
thanks i'll try that.
JOHN
463515
Reply By: Member - P Koch - VIC - Friday, Aug 26, 2011 at 13:48
My daughter had a BA and some times the boot would not shut properly and cause this problem
Regards Paul
463580
