Clear H4 Lights Toyota Landcruiser on ebay, are they any good ???
Submitted: Monday, Aug 15, 2011 at 19:39
ThreadID: 88485 Views:4139 Replies:4 FollowUps:7
i am looking at "Clear H4 Lights Toyota Landcruiser" as listed on e-bay, has anybody fitted them or have any feed back about them.....
I am going away on hols and have realised i never use low beam out here and it is hopeless on low beam ..
Ta
Joe
Reply By: Member - Joe n Mel n kids (FNQ - Monday, Aug 15, 2011 at 19:49
sorry, should add they are for a 75 series..
AnswerID: 462681
Reply By: brianc - Monday, Aug 15, 2011 at 19:52
Not sure exactly which lights these are. If they are the 7" round jobbies, the best thing I did to my HJ60 was to ditch the original lights, put in Hella inserts with the H4 globes and then a wiring kit to get the volts where they need to be. Instant daylight.
AnswerID: 462683
Follow Up By: Dave B ( BHQ NSW) - Monday, Aug 15, 2011 at 20:29
I'll second that Brian.
Dave
'Wouldn't be dead for quids'
FollowupID: 736505
Follow Up By: Member - Joe n Mel n kids (FNQ - Monday, Aug 15, 2011 at 21:17
They are the 7" ones, i guess they would be the "no name" copys of Hella inserts, i have heard the wiring harnes is a good improvment, should really look at it also eh.. how much were the Hella units ???
Cheers n thanks
Joe
FollowupID: 736510
Follow Up By: Dave B ( BHQ NSW) - Monday, Aug 15, 2011 at 22:44
Joe, I don't know how much the H4's are now, but when I got mine they were cheaper than OE from Toyota.
I had to replace one because a roo stuck his head in the way.
Obviously I got a pair of H4's.
Dave
FollowupID: 736514
Follow Up By: Member - Tony H (touring oz) - Monday, Aug 15, 2011 at 22:50
Hi Joe,
Good idea, buy these lights then fit an HID conversion.... simply brilliant
FollowupID: 736515
Follow Up By: Member - Joe n Mel n kids (FNQ - Monday, Aug 15, 2011 at 23:10
I am not really keen on the HID's in low beams, in spots yes but i really hate it when other are coming towards me with them and it is simply to bright to see anything, i have heard others make that comment also so in respect of "others" i probally wont go them in normal lights ... yet ....
FollowupID: 736517
Reply By: Member - Murray R (VIC) - Monday, Aug 15, 2011 at 22:27
Joe
Hella have the best light beams, i've tried many different brands of inserts and they all seem very wishy washy in beam spread and penetration compared to the Hella's which are not cheap but money well spent. Also fit the wiring kit and get some plus 60% h4 globes, don't go for the plus 80% or the 80/100 watt globes as these don't last. Hope this helps your decision.
cheers Murray
Another Mexican
AnswerID: 462702
Follow Up By: Member - Joe n Mel n kids (FNQ - Monday, Aug 15, 2011 at 23:17
Thanks Murray, i will check out Hella pricing tomorrow, it was my worry that it may be a risk as they really dont have any "brand" so may not be very good, my HI beams are fine but i dread driving at night in any city (hate it at day!!!) so i need the best i can get i guess, i get wifey to drive at night when on hols as i have declaired it as sun down, on hols, time for drinkys not drivin ... hahaha
I very nearly brought them but thought i perhaps should pop the question first and glad i did..
Cheers guys,
Joe
FollowupID: 736519
Reply By: Member - jethro - Tuesday, Aug 16, 2011 at 20:42
Joe,
I have the Hella H4 upgrade in my 75, had it in for best part of 7 years, I agree with you on lowbeam the 75's aren't much better than a candle.
I put in 65/100 bulbs with a relay and haven't had any trouble at all.
Geoff.
AnswerID: 462761
Follow Up By: Charlie B2 - Wednesday, Aug 17, 2011 at 13:32
Hi all,
I set up a Hella H4 upgrade in my '86 HJ60 somewhere around '92 or '93, with my own 6mm (automotive) wiring (no commercial wiring looms readily available when I did mine) and some BIG H4 globes which absolutely transformed things for travel after dark. Not that we ever did much of that - it was more of a comfort thing.
A 'roo's head put paid to the LHS headlight and I had difficulty sourcing a new Hella, so looked at a generic brand, which was made in India, that was fairly readily available through the automotive chains back then, but the reflectors really weren't satisfactory for my needs.
Eventually got hold of a single Cibie H4 conversion, so I ran a mismatched set for about 6 years. I didn't notice a huge difference in performance between Hella and Cibie, but what there was favoured the Cibie. From memory (I sold the vehicle back in 2007), Hella had a flatter glass and an extra hole in the reflector for an in-headlight parking globe, with a rubber/plastic grommet to keep water out if you weren't using that arrangement, while Cibie had a rounder glass with some raised lines in it, perhaps for lateral light dispersion and an undisturbed reflector.
The orienting/locating sytems were the main structural difference - Hella used a quite solid, welded-on, thick square "wire", while Cibie used relatively flimsy strips of sheet metal, on edge. That said, both travelled several hundred thousand kilometres without any mechanical failure and provided a vast improvement over the ridiculous sealed beams that were standard in these vehicles long after everyone else in the automotive game had gone to H4's.
Regards,
Charlie
FollowupID: 736595
