Saturday, Aug 13, 2011 at 21:31
Yeah they do have to be done up tight, as you could imagine with kids, they learn all over it as if i was a work bench, so we do ours up real tight.
Is it the clamp( black plastic knob/wheel) at the base or top that doesn't tighten up enough on the pole/shaft that allows the movement? Maybe the Split in either end needs a cut a little wider, to pull it tighter or maybe the thread is stripped and a wing nut or something else used.
Or is it the base that fixes to the floor that is allowing the movement? sometimes the screws can work their way loose. Is the top plate of the table top assembly fixed to the table top properly?
Hope this is of some help.
Jon
736319
