Toyota HJ75 hubs on a trailer with brakes
Submitted: Monday, Jul 18, 2011 at 19:33
Member - Serendipity(WA)
I have a trailer that has original hubs from toyota - hj75 hubs.
I want to add disc rotors so I can have brakes on the trailer. Can I purchase the disc rotors and will the rotors just slip over the hubs or do the wheel studs get knocked in from behind the disc rotors and then through the hubs thus sandwiching the disc rotor to the hub.
I intend to then use some commodore calipers mounted on a sturdy bracket welded to the axle.
Seems possible. Just wondering how the disc rotors will fit on.
Serendipity
Reply By: GrumpyOldFart - Monday, Jul 18, 2011 at 20:04
Serendipity
I think they are the same setup as my 105
The discs sit on the hub located by the wheel studs and held on by a screw just like brake drums.
Any Landcruiser 6 stud disc should fit, even 80 series, front or rear.
You may want to look at XD -E- F Ford rear callipers as they have a handbrake built into the calliper unlike Commodore that have a separate set of shoes for an internal drum.
Have fun
Dru
| Remember
Life is short, Break the rules, Forgive quickly, Kiss slowly, Love truly,
Laugh uncontrollably, And never regret anything that made you smileLifetime Member My Profile My Blog Send Message |
460314
Follow Up By: Member - Serendipity(WA) - Monday, Jul 18, 2011 at 22:38
thanks Dru
Want to keep it simple and not involve a separate brake cable - will just use the lever that is part of the tow hitch and a brick when
parking the trailer.
Serendipity
733989
