Trifor winch - how to use it!
Submitted: Sunday, Jul 17, 2011 at 16:25
ThreadID: 87627 Views:3781 Replies:12 FollowUps:15
G'day everyone, I just bought a nice Trifor winch at a swap meet, looks like it has had little use. Now I have to learn how to use it! Any tips, tricks or hints would be greatly appreciated, thanks
"the only thing constant in my life is change"
Reply By: Sir Kev & Darkie - Sunday, Jul 17, 2011 at 16:29
Tip #1, if your not fit ................... Sell it,
Tip #2, get stuck with someone fitter than you ............ let them do all the work,
Tip #3, for small distance recoveries they are great :)
Cheers Kev
Russell Coight:
AnswerID: 460203
Follow Up By: Member - hopbush - Sunday, Jul 17, 2011 at 16:46
Excellent advice Kev...but seriously, the best way to learn is to get stuck somewhere.
Also...make sure you have spare sheer pins and buy a reduction pulley block to reduce the personal effort.
Good luck
Tony
FollowupID: 733841
Follow Up By: aussiedingo. (River Rina) - Sunday, Jul 17, 2011 at 18:12
Are spare sheer pins likely to be hidden on the unit somewhere?
FollowupID: 733862
Follow Up By: Sir Kev & Darkie - Sunday, Jul 17, 2011 at 18:32
Spare shear pins are usually in the handle ;)
Cheers Kev
Russell Coight:
FollowupID: 733867
Follow Up By: aussiedingo. (River Rina) - Monday, Jul 18, 2011 at 09:04
Thanks Kev, where actually do the shear pins fit? do you know what size they are? thanks, Norm
FollowupID: 733926
Reply By: Notso - Sunday, Jul 17, 2011 at 16:47
There is a user manual here Tirfor Manual
It is in about 5 languages so save it and scroll through till you find the English version
AnswerID: 460204
Follow Up By: aussiedingo. (River Rina) - Sunday, Jul 17, 2011 at 17:34
Thanks Notso, I just downloaded a copy of the manual, great! thanks again
FollowupID: 733849
Reply By: Member - Richard W (NSW) - Sunday, Jul 17, 2011 at 16:58
Last time I used one in anger was to pull out a stump. LOL
First time I had used it and it wasn't too hard.
AnswerID: 460205
Reply By: Crackles - Sunday, Jul 17, 2011 at 17:23
Dingo suggest setting it up at home to practice before using it in anger paticually opperating the clutch. I put the Tirfor up at the anchor end not the car end so that as you winch you stand in the one place and not move with the car. It pays to have a long tree protector or short extension so the Tirfor handle doesn't hit the tree you're winching off. Keeping the cable clean is important to avoid getting too much dirt inside the winch. A winch extension will be advantageous as the standard cable is not particularly long. A snatch block will be needed for all but the easiest of recoveries.
While very handy at times don't expect too much from your Tirfor. They are extremely slow and alot of hard work. A recovery the length of the cable from a bog hole could take two hours or more!
Cheers Craig.
AnswerID: 460207
Follow Up By: Bigfish - Sunday, Jul 17, 2011 at 17:32
Dead right mate. One of the few times in my life I have been knocked out is when using one of these instruments of tortue. . Clean it, advertise it and clap your hands when it is gone.
FollowupID: 733848
Reply By: Member Al (Sunshine Coast) - Sunday, Jul 17, 2011 at 18:06
Aussiedingo, did you happen to ask the seller why he was selling the winch?
Maybe you are beginning to get some idea of why!
AnswerID: 460211
Follow Up By: aussiedingo. (River Rina) - Sunday, Jul 17, 2011 at 18:09
G'day Al, it was part of a deceased estate from an old Landrover owner.
FollowupID: 733860
Follow Up By: Fatso - Sunday, Jul 17, 2011 at 19:33
G'day Ausiedingo.
They didn't happen to mention how he died & why the tirfor had to go did they?
FollowupID: 733880
Follow Up By: aussiedingo. (River Rina) - Sunday, Jul 17, 2011 at 19:41
NOT NICE! respect.
FollowupID: 733881
Reply By: snoopyone - Sunday, Jul 17, 2011 at 18:10
HA HA endorse all the comments.
We had one when I worked in Fiordland in the 60's.
Only way of getting our jetboat out of the water was one of these.
Could take ages if the water was low LOL
Also had to use it twice when firstly the tractor McCormack B250 sort of ended up in a tree perched over a river Had to walk 600m to get it and carry it and 100ft of wire rope back to the tractor and winch it back onto the track, then carry the winch back as couldnt turn the tractor around.
Second time the other tractor a Fergie sort of fell over on its side in a soft spot So off I went for 1 1/2km this time and carried it back and wrapped rope around the Fergie and dragged it back up onto its wheels. Then had to pack branches under wheels to get it back on the track.
Lots of fun and glad I no longer have one .
AnswerID: 460215
Follow Up By: ben_gv3 - Sunday, Jul 17, 2011 at 19:55
But I bet you were glad you had one back then ;-p
FollowupID: 733884
Follow Up By: snoopyone - Sunday, Jul 17, 2011 at 20:07
Yes I was but back never recovered and they are pretty heavy if using a long rope like we had.
Boss wouldnt have been happy if tractor had gone over the edge but we eventually did manage to sink it by overturning a raft it was on when going for maintenance.
That is another story however
FollowupID: 733886
Reply By: Michael ( Moss Vale NSW) - Sunday, Jul 17, 2011 at 18:30
Deceased estate!! I probably killed him.. You need a longer lever and even longer arms!! WE used one many years ago winching a SWB Toyota up the Spanish steps, up the Blue Mountains from memory.. Not fun !!
Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.
AnswerID: 460223
Reply By: sweetwill - Sunday, Jul 17, 2011 at 18:41
Dingo.
used one in the mines years ago, and yes they do work, bit of yakka yes, but it will get you out of trouble,cheers bill.
AnswerID: 460224
Follow Up By: Ray - Sunday, Jul 17, 2011 at 19:24
Yes I used one in the mines years ago also. Great tools if used correctly. You will be amazed at what you can pull but don't put the Tirfor cable around a snatch block as they do not like tight bends. Get yourself a length of cable for this purpose and don't use bulldog clamps on the tirfor cable as it is special cable and is not designed for this. Get yourself a length of standard cable with a swagged eye one end large enough for the Tirfor cable.
FollowupID: 733877
Reply By: Member - Mark E (VIC) - Sunday, Jul 17, 2011 at 21:31
For anyone who travels alone, the tirfor is about the best piece of recovery equipment you can have in your arsenel.
It can pull your car sideways, backwards, frontwards or at a greater angle than any electric winch can.
It does not rely on battery power or engine running.
Yes, they are slow, but no recovery should ever be done quickly (perhaps with the exception of incoming tide.... 8-0 )
And, as an added bonus you will develop biceps to rival Arnold Swartzenegger and a lung capacity of Steve Monegetti.
I have used a Tirfor MANY times over the years and would never sell mine. I still carry it when on solo trips in the High Country, despite the current car having a Warn 12,000 on the front.
If you would like, I could copy my Instruction Manual for you and send it to you, I will just need an address to post it to via snail mail. I'm not too sure whether these exist electronically. PM me if you like.
Ignore the above ridiculous advice of selling it...... provided you can still see that you have feet beyond the beer gut, you should be able to use it in most sticky situations. A bit of huff and puff is good for the heart and soul.
I bet Tom Hafey wouldn't shy away from throwing the Tirfor around to de-bog his new Jeep. More than likely he'd pull it out with a bit of rope between his teeth!!!
A few out there need a few HTFU pills!!!
Mark
AnswerID: 460248
Follow Up By: Brian Purdue - Monday, Jul 18, 2011 at 08:10
Being old and senile (and bone lazy!), I prefer not to get stuck. I drive away from boggy places and go somewhere else.
FollowupID: 733923
Follow Up By: Member - Mark E (VIC) - Monday, Jul 18, 2011 at 09:01
That is a great theory....and just that....theory. I also prefer not to get stuck, but as the saying goes *hit happens!!
Mark
FollowupID: 733925
Follow Up By: Brian Purdue - Monday, Jul 18, 2011 at 10:02
The last time I was ever bogged was on a Duetz tractor in 1950. It took two days to dig it out. A lesson well learned and never forgotton. When I read some of the snide remarks here (and yes I have made the odd one) I recall reading a magazine where the title of the article was "You cannot get there from here". Now that is really the truth if you have a negative attitude. If you can get to a boggy place you just go back. Easy!
Ah ha! you say. "I did not know it was going to be boggy" Ah ha, says I did you walk and have a look?
Now 1950 was a looonnnngg time ago and I have spent many years driving beaches, floodways and thick bush, breakaways etc. If something warns me in any way, I get out and go have a look. That is why I am old, senile and bone lazy.
FollowupID: 733932
Reply By: brushmarx - Monday, Jul 18, 2011 at 09:37
Don't panic, the doomsayers probably need to man up a bit.
Tirfor's can be really hard work if not operated correctly.
They can hurt you if not used correctly.
They can save your life if used correctly.
They can save your vehicle if used correctly
Like anything based on leverage, the longer the lever, the easier the work.
If you have to use it, ensure the handle is extended, and use the full length of it. A shorter handle requires less body movement, but makes the task harder.
Like any tool, respect it.
Sure, electric winches are quicker and easier, but not necessarily as useful in some situations. Tirfor's don't rely on battery power, or the engine running.
Wear leather gloves, take care, and plan your recovery well.
AnswerID: 460273
Reply By: ob - Monday, Jul 18, 2011 at 11:07
Like others have said, the Tirfor hand winch is a useful bit of kit used correctly. Firstly get a good length of pipe to extend the handle, I have a piece of aluminium tube about 1 1/2" diameter and about 4 foot long. Don't let anyone tell you it 'aint hard work but they do the job. Just the thought of having to use it a second time makes you look a bit harder before driving into a situation where it may be needed.
ob
AnswerID: 460280
Reply By: Fatso - Monday, Jul 18, 2011 at 20:17
Bought a Beaver (same thing as a tirfor) about 15 years ago.
Only ever used it to straighten up a fence post.
It is the cheapest way that you can get a reliable winch.
You may be lucky enough to never use yours either.
A bit of wisdom can save you a lot of sweat.
AnswerID: 460316
