Sunday, Jul 10, 2011 at 13:26
You might not have a problem but I sure many who like canning CRD engines have...LOL
With the D4D there is no sure way of knowing the cause as some vehicles that are only used around major cities fail and ones in the outback don't.
Water is the biggest problem due to it's abrasive and corrosive properties, CRD injectors have micro finishers and very very small tolerances that can be destroyed very easily.
There is no problems with restrictions regarding adding a second filter (primary), there was lots said at the start regarding adding extra filters but non have been proven.
Most secondary filters are between 5 to 10 micron as compared to 2 micron and a dirty filter works better then a clean one as long as it's not restrictive.
I would leave changing the factory filter until needed or as directed, there is a greater chance of getting foreign bodies into the fuel system the more you change the factory filter.
The factory filters are very good quality, have a very large filter area and with good filtering properties.
Toyota CRD engines don't need any maintenance except for draining the water trap.
I would say the filter and warning light worked as required and may of been over looked whilst driving (some are fitting warning alarms as they don't see the light come on), after all it is a very small light.
We changed our secondary filter (primary) every 30,000 kilometers and the factory filter got changed at about 90,000 kilometers when the light came on warning of a restriction.
Our secondary filter (primary) had a larger water trap just in case we got water in our tank.
Just a note:- when the dash light stays on it is indicating a restriction and when it flashes it's indicating water in the water trap.... the second warning may already be to late.
I am still working out what system I'm going to use on our V8 Landcruiser.
733144
