Thursday, Jul 07, 2011 at 11:34
You're welcome Scoof,
note the batteries aren't the limiting factor in a solar system. The question is, is the panel large enough to supply enough juice to power all the loads over a longer time span.
The batteries are just there to fill the gaps in power supply if no sunshine.
They also act as high energy buffer, as they're capable of churning out lots more amps for a short time, than any solar panel.
By the looks of it your solar panel keeps the N70ies charged easily, so you could just as
well use bigger batteries which can store more energy, saving you a bit of outboard motor run time.
Batteries only get damaged if you discharge them more than the solar panel can supply over a few days, so just keep an eye on their voltage which should be 13.6~13.8V for much of the time.
A good solar regulator will let this voltage increase in a controlled way, depending on how deeply the battery gets discharged at night.
cheers, Peter
732909
