EO Track Me co-ordinates
The EO Track me uses a co-ordinate system that isn't Lat/Long. I did a conversion a fair while ago to Lat/Long but can't remember where I found the converter.
Can anyone assist?
thanks
Paul
Reply By: Member - Rod N (QLD) - Friday, Jul 01, 2011 at 12:48
It looks like lat/long to me, It is in decimal degrees not degrees, minutes and seconds. I think there was a thread on this not so long ago. There is a conversion program (excel) in the members file swap area.
AnswerID: 458957
Follow Up By: Member - Ups and Downs - Saturday, Jul 02, 2011 at 16:29
I tried a search but as usual it came up with everything but the info I was after.
Yes, you're right it is decimal, sorry for my ignorance. I found the conversion and all is good now.
thanks
Paul
FollowupID: 732570
Reply By: Member - The Bushwhackers -NSW - Friday, Jul 01, 2011 at 23:26
G'day Ups and Downs,
If as Rod N says, you only need a converter, you will find a program called 'Co-ordinate Converter' in Conversion and Calculation Tools, in Members Fileswap.
It is not a spreadsheet, but a small program that my son in law wrote for me, so no need for MS Excel.
Neat & tidy, and works a treat.
Cheers, Dave
AnswerID: 458999
Follow Up By: Member - Ups and Downs - Saturday, Jul 02, 2011 at 16:31
Thanks Dave,
As explained I didn't understand the subject good enough.
The program worked well and solved my problem. Thank son in law for me.
Paul
FollowupID: 732571
Follow Up By: Member - The Bushwhackers -NSW - Saturday, Jul 02, 2011 at 17:56
Paul, you're quite welcome. Will pass on thanks.
Cheers, Dave
FollowupID: 732579
