Darwin ARB and Long Ranger Tanks
Submitted: Monday, Jun 27, 2011 at 17:51
Member - Cozzie Toodyay (WA)
I had a noise coming from my Holden Colorado when parked up for the night sounded like chickens clucking under it, turned out to be the fuel tank breather, rang Long
Ranger tanks they sent me to ARB
Darwin who got straight on the job and sorted it while I waited, so a big thanks to both of these companies.
Cozzie
Reply By: Michael ( Moss Vale NSW) - Monday, Jun 27, 2011 at 19:55
Cozzie!! Lucky you didn't have a fowl smell with that noise!!! :)) Michael
| Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.Member My Profile My Blog Send Message |
458596
Follow Up By: Member - Cozzie Toodyay (WA) - Monday, Jun 27, 2011 at 20:17
Hey Michael, lucky they found the problem or I may have ended up with egg on me face.
Cozzie
732130
Reply By: Member - Doug T (NT) - Tuesday, Jun 28, 2011 at 01:27
You gotta watch out for little wasps up here, they will build a mud nest up the A/c drain pipe , next thing you notice is water on the floor when it over-flows, easy fixed by stuffing a piece of nylon fly wire 1/4 inch up the pipe.
So could it have a nest in the breather .
458623
Follow Up By: Member - Cozzie Toodyay (WA) - Tuesday, Jun 28, 2011 at 08:47
Could have been a wasp nest ARB just said it was red dirt, thanks for the heads up Doug will chech out the A/C drain
732158
Reply By: nickoff - Tuesday, Jun 28, 2011 at 10:45
How a wasp can ground an aircraft.
Interesting story about mud wasp nests in Dr Clyde Fenton’s book. I read this many years ago, and has stuck in my mind ever since.
He made a number of power out force landings in the NT during his time here but was unable to find the cause of the engine shut down, apart from it being caused by fuel shortage, even though the aircraft had fuel in the tank. He was flying in a Tiger Moth and they gravity feed fuel to the engine from a tank in the upper wing.
Eventually he noted that the engine only starved for fuel after he had flown through moisture or rain. This stranded (Grounded) him on a number of occasions. Further investigation located a mud wasp nest in the breather hole inside the fuel cap. When it was dry, it allowed enough airflow through to allow the tank to gravity feed to the engine, but when it got moist, airflow through the mud ceased, and caused a vacuum in the tank that prevented the fuel flow and shut down the engine.
Again, from memory and reading BASI Crash comics and historical aviation books, there has also been similar circumstances where aircraft in the tropics have been grounded or crashed by these pesky wasps building their nests in the pitot tubes.
I have used this technique to shut down pesky noisy generators in the past. Lick to moisten a tiny piece of cigarette paper about ½ the size of your little fingernail, and put it over the breather hole in the generators fuel cap. Within 10 minutes or so the engine will “starve” of fuel and shut down. Once shut down the paper quickly dries off and blows away or falls off, leaving no trace.
458646
Follow Up By: ben_gv3 - Tuesday, Jun 28, 2011 at 13:23
"I have used this technique to shut down pesky noisy generators in the past. Lick to moisten a tiny piece of cigarette paper about ½ the size of your little fingernail, and put it over the breather hole in the generators fuel cap. Within 10 minutes or so the engine will “starve” of fuel and shut down. Once shut down the paper quickly dries off and blows away or falls off, leaving no trace.
Very sneaky indeed :-)))
732171
