Wednesday, Jun 22, 2011 at 10:45
Hi Peter of BW
Re:"quote"Note that an earthed system without RCD is more dangerous, than a non earthed (floating) system without an RCD.
The best protection is offered by an earthed system with RCD, because the RCD detects any insulation
breakdown between active/hot and associated leakage current from this wire to earth. So there's no chance that something can become 'life'.
But if the RCD goes faulty, you end up with a dangerous earthed system without RCD, thus the importance of periodical tests carried out on the RCD[end quote]
Exactly the reason I post that floating systems are not as safe as some believe or make out
An insulation fault can exist & lie dormant, without ANYONE knowing they now have an earthed neutral system .
The fault can be anywhere in the system INCLUDING equipment & THAT is the main reason for only having ONE CLASS 1 DEVISE CONNECTED
THAT has been the long accepted safety practise for many many years.
It does not matter how good the soource's insulation is, the earth fault can /does / has occuured elsewhere.
This is something that many do not seem to understand.
This is the reason that it is now mandatoryfor buiders , constuction ,tc to have PERMANENTLY fitted RCDs to ALL generators
Accidents , including deaths did occur with the supposidly safe fully isolated sources .
BUT I cannot agree with this
[quote]"
In a nutshell, if the RCD is already installed inside your van, I'd connect the generator chassis, van and towing vehicle with an earth wire (common negative, or chassis ground is suitable). This earth wire needs to be connected to the 240V power outlet socket on the gennie, and to the neutral on the same socket, via the extension cord between gennie and van.
Ask an electrician who can tell you which one it is.
For the ultimate protection, also use a plugin type RCD at the gennie 240V socket[end quote]
The standards demand that if the portable generator has an earthed neutral then an RCD Should be PERMANENTLY FITTED & WIRED to the generator.
A plug in RCD is not acceptable.
Under no circumstances should ANY ONE other than a qualified electrician attempt such modification.
Doing so is illegal & leaves the person open to expensive & serious charges
A further reason is that some inverter gennys require a specific RCD for correct operation
The common earth wire should only be the the one in the connecting cable,[extension lead ]no other is required or needed
& should ONLY BE CONNECTED TO THE EARTH PINS!!
731528
