Biodegradable toilet paper
Submitted: Friday, Jun 17, 2011 at 07:04
Kiwibound eventually
We have recently purchased a Jayco Sterling van with full ensuite. During the delivery walk through the consultant told us that we must use biodegradable
toilet paper. Of course, none was supplied with the van. We are preparing to leave
Melbourne in two weeks at the commencement of a twelve month trip around Australia. Please help us. Do we need to source this particular
toilet paper or can we use standard household
toilet paper sparingly? If we need to buy biodegradable paper where is this purchased?
Reply By: Darren H1 - Friday, Jun 17, 2011 at 07:08
I think you will find most
toilet paper is biodegradable these days.
457676
Reply By: Dennis Ellery - Friday, Jun 17, 2011 at 10:57
BCF sells fast
breakdown toilet paper for the use in chemical
toilets.
I have never used it.
The standard stuff doesn’t
breakdown completely in our standard chemical
toilet (it doesn’t have time) – but it’s bio-degradable as is newspaper etc.
457702
Reply By: landseka - Friday, Jun 17, 2011 at 11:55
Hi there, we use Cottonelle in ours, never a problem. At empty time there is only a slurry, no sign of
toilet paper.
We don't use the nasty chemicals, we use generic nappysan type stuff which does the job perfectly and MUCH more cheaply.
Cheers Neil
457707
Follow Up By: Lex M (Brisbane) - Friday, Jun 17, 2011 at 12:06
I'll second the cottonelle and generic nappysan. Way to go. Never had a problem.
730896
Follow Up By: Pete Jackman (SA) - Friday, Jun 17, 2011 at 13:00
x 3
Same here as
well with no isses
Pete
730903
Follow Up By: Sawtybt - Friday, Jun 17, 2011 at 13:55
We use TST brand. It's an RV and Marine
toilet tissue and is 100% biodegradable and free from dyes and perfumes. It's ultrasoft and is 1 ply. Breaks down easily.
730908
Reply By: Member - David 1 - Friday, Jun 17, 2011 at 14:14
Hi Kiwibound,
I believe that "special"
toilet paper for caravan loos is a bit of a con. We always use the regular household variety without any problems. Yes, there are occasions when the paper only breaks down to a papier-mache look a like.
The suggestion of using cottonelle sounds good, I'll try it.
Regarding the use of Napisan; it doesn't work
well if anyone is on some kinds of prescription medication (don't know what kinds). However, if you
check a Napisan label for the active ingredient you will see that it is somewhere about 23%.
Check around for a generic brand because the same active ingredient is at least 10% more. This works much better because more oxygen is present to assist in the
breakdown process.
David1
457723
Follow Up By: Stu & "Bob" - Saturday, Jun 18, 2011 at 09:37
Any sort of penicillin derivative (amoxil, amoxcillin,etc) medication will stuff up a
toilet system.
Even more so in a septic system, chuck a bit of brewer's yeast in there, that will start the system again.
HTH
731002
Reply By: Member - Heather MG NSW - Friday, Jun 17, 2011 at 15:04
Hi Kiwibound eventually,
We use a 2 ply
toilet paper...Woolworths or Coles brands are ok. They break down
well and don't take up valuable space in the holding tank. Works for me...much better than the thicker varieties which we used to use.
We have a Jayco sterling outback and this is our fourth winter travelling in it so have plenty of experience, and we travel for more than half of every year.
I know others use Napisan or other nappy products instead of chemicals but we have tried them without too much success. The
toilet had to be emptied every few days and began to smell.
We now use the blue Thetford chemical and it is fantastic. Also in the top tank we add a small amount of Milton steriliser which cleans the bowl with every flush. Have just emptied our holding tank after 8 days and it had no odour. (not even to the hubby who doesnt usually use it and has to empty it!)
Regards,
Heather
457725
Reply By: Member -Dodger - Friday, Jun 17, 2011 at 16:37
I'll third the generic nappysan. Way to go. Never had a problem.
I mt the cassette around the three day mark or before it gets completely full and there is usually just the brown sludge to mt.
If you are on the move then the action of the van agitates the slurry very quickly.
We use ordinsry good quality 2 ply paper.
457728
Reply By: Kiwibound eventually - Friday, Jun 17, 2011 at 17:10
Thank you very much for all your replies. This is extremely helpful to us and certainly shows the benefit of being able to ask a question and receive the opinion of many knowledgeable people. We will try your ideas. Thank you so much.
457729
Reply By: Motherhen - Friday, Jun 17, 2011 at 20:40
Hi Kiwibound - so long as it says septic safe (doesn't it all?) it will do the job. With a bit of liquid in the cassette and the movement of the road, it dissolves in next to no time.
457749
Reply By: Sand Man (SA) - Friday, Jun 17, 2011 at 22:19
The only "concession" we make is that the
toilet paper we use is unbleached.
We also use "
Home Brand" Nappysan as the only means of breaking down the solids and it works extremely
457765
Reply By: paulnsw - Saturday, Jun 18, 2011 at 14:09
From formal testing Kleenex Cottonelle
toilet paper breaks down quicker than any other
toilet paper including the so called special
toilet paper sold by
toilet manufacturers. When you empty your cassette with Kleenex Cottonelle there will be no visible paper at all. Most mobile
toilets you see at events use Cottonelle to prevent the pipes plugging up.
457799
Follow Up By: Kiwibound eventually - Sunday, Jun 19, 2011 at 08:54
Thank you so much - we often use the Kleenex Cottonelle at
home (normally when on "special" at the
supermarket. It will be the "choice" from now on. Appreciate everyone's time to advise and assist us.
731145
Reply By: achjimmy - Sunday, Jun 19, 2011 at 08:15
Another user of Thetford blue, very effective with both #1's&2's but bloody expensive.
457863
Follow Up By: Kiwibound eventually - Sunday, Jun 19, 2011 at 09:00
We were conscious of the ongoing cost of the Thetford Blue and as we are trying to put some boundaries around ongoing travel costs thought I would
check and see what others use. At this stage the
toilet has not been used. We will try both the Thetford Blue (one of which was supplied with the van) and the Napisan and
home brand equivalents. Thank you for your advice.
731146
Follow Up By: Lex M (Brisbane) - Sunday, Jun 19, 2011 at 20:07
Be aware that after using the blue, or any other of the usual chemicals, that the tank will have to be thoroughly washed several times with a strong generic nappy treatment solution before the nappy treatment chemicals will work successfully.
We use a generic nappy treatment from one of the large
supermarket chains, in the bottom tank and again after three days if you haven't emptied it yet. It's cheap enough to do that.
Also a good dash of detergent in the top
water tank and a short flush before use to wet the bowl helps keep things easier to clean.
731226
Follow Up By: Lex M (Brisbane) - Sunday, Jun 19, 2011 at 20:10
Should have said:- cap full in bottom tank and again every three days if not emptied.
731229
Follow Up By: Kiwibound eventually - Sunday, Jun 19, 2011 at 21:07
Thanks Lex for your advice and clarification on how much to use, as again we had no idea. Also a good idea about the use of detergent in the top tank. Wouldn't have thought of that. Anything to make the whole process easier is much appreciated.
731237
