jammed uhf
Submitted: Monday, Jun 13, 2011 at 12:17
oz doc
HI all, went to use our portable uhf on the weekend and it appears to have malfunctioned. It is a Uniden UHO65sx. It is stuck on "busy". I have done a quick internet search and it would appear that this is a frequent problem with these units. I was wondering if anyone has experienced similar and sent their unit in for repair and a rough idea on how much it cost to fix. If it is going to be an expensive rigmarole I don't think I will bother. Cheers, doc.
Reply By: Mudripper - Monday, Jun 13, 2011 at 13:03
You don't by any chance have the squelch set really low or turned on the "MON" (open squelch) feature?
I have a pair of Uniden UH720SX handhelds and they have a "MON" feature which opens the squelch and gives a "BUSY" signal, so not really sure about yours.
Tim.
457269
Follow Up By: oz doc - Monday, Jun 13, 2011 at 13:20
Thanks for the suggestions Tim- no I checked all the settings. Internet search suggests it will be a 'broken ceramic coil' whatever that is. Beats me how it broke- been stored in the cupboard for months. Bit annoying as the unit has had very little use and been
well looked after. I'm not having much luck with electronics at the moment. My Magellan GPS is also on the fritz.Cheers, doc.
730401
Reply By: MEMBER - Darian, SA - Monday, Jun 13, 2011 at 13:43
.......it's a pain alright when they fail without good reason ... even more so when the new UHF regs have sent the value of every 40 channel radio plummeting - $ spent on repair is probably bad economics.
457273
Reply By: Shaker - Monday, Jun 13, 2011 at 13:46
Have you tried removing & refitting the batteries?
457274
Follow Up By: oz doc - Monday, Jun 13, 2011 at 13:50
Thanks Shaker, that was the first thing I tried.doc.
730405
Reply By: Member - Gary W (NSW) - Monday, Jun 13, 2011 at 17:42
I had the same problem and rang Uniden.
My memory is now failing (haha) but I'm sure that I returned it to them and they fixed and returned it very promptly.
I'm sure that it was totally free (may have had to pay postage to them), but you can
check that when you call them.
Gary.
457298
Follow Up By: Member - Boobook - Monday, Jun 13, 2011 at 17:48
Yep it is a very very very very very common problem. Stuck on "busy"
When you ring them they will pretent that you are the first person that has ever had the problem. Send it to them under warranty - they have a free return post - and then refuse to pay for it after it has been fixed. They will waive the bill.
730426
Follow Up By: oz doc - Monday, Jun 13, 2011 at 19:03
Thanks Gary but it is no longer under warranty so I doubt they will fix it for free. A call to an authorised repairer today confirmed- it is a most common problem, quoted $45 to look at it and would not give me a price to fix it until they
check it out. doc.
730437
Follow Up By: Member - Boobook - Tuesday, Jun 14, 2011 at 06:15
oz doc, even though it is out of warranty they ofen fix them. I had one fixed that was 2 years out of warranty. Give it a go.
730485
Reply By: MEMBER - Darian, SA - Monday, Jun 13, 2011 at 21:15
Direct contact with Uniden is probably the go - you do have statutory rights for a fair operational life of the product. The manufacturer's offered warranty is not the end of the matter.
457330
Reply By: Member - Troll 81 (QLD) - Tuesday, Jun 14, 2011 at 11:07
Mine has done the exact same thing same model number all the research I did pointed to a dry solder joint.
I threw
mine in the bin I got good service out of it.
457372
