Nissan X-trail hazard lights
Submitted: Tuesday, Jun 07, 2011 at 21:57
willawa
If you own a 2007-2008 X-Trail and have found that the
hazard lights will not work when your trailer is attached unless the ignition is on or switched to 'accessories 'it will require a sub harness to be fitted for it to work. In the UK they had a recall but Nissan Aus. will not do it here.
I believe this is a safety issue and you should contact Nissan or your local service dealer to register your concern.
