Ozi Explorer on Ipad 2
Submitted: Tuesday, Jun 07, 2011 at 11:45
CraigB
Can anyone advise if Ozi Explorer can be run on Ipad 2
Reply By: The Explorer - Tuesday, Jun 07, 2011 at 12:07
No it can’t, but apparently a version is planned, presumably once work on fine tuning the Android version (now out) becomes less onerous.
456680
Follow Up By: CraigB - Tuesday, Jun 07, 2011 at 12:27
Thanks Greg
729770
Follow Up By: The Explorer - Tuesday, Jun 07, 2011 at 12:34
Note: we are talking OziCe here. It appears there are no plans to make OziExplorer for anything other than Windows by the looks??
729772
Follow Up By: Member Dick - Tuesday, Jun 07, 2011 at 17:29
You can get a version of VMS to run on the iPad. I have it on the iPad2 and it looks useful.
729793
Follow Up By: Member - Boobook - Tuesday, Jun 07, 2011 at 18:33
Greg, they just released the Android version 1.0
check the link on the page above.
729805
Follow Up By: The Explorer - Tuesday, Jun 07, 2011 at 19:29
You mean the link I provided:)
Yes its up to version 1.05 after only 4 days. As I said, once the Beta Android version "stabilises" the Ozi crew may then have time to concentrate on other versions.
729817
Reply By: rkg44 - Tuesday, Jun 07, 2011 at 16:38
Reply By: The Explorer - Tuesday, Jun 07, 2011 at 19:27
Hi again
Just to confuse you there is also
TwoNav.
I use TwoNav Aventura - I like it.
456720
Reply By: Echucan Bob - Tuesday, Jun 07, 2011 at 20:38
Craig
I run all my Oz2f maps (Hema Maps, Westprint, NSW and VIC 1:100,000) using Bitmap.
For 1:250,000 I use Memory-Map. You can download for free all the regions you want at this resolution.
I just switch between Bitmap and MM.
The iPad is the perfect size for navigation, and has replaced all the computers, touch screens, external displays, USB GPSs etc that I used to need. The mount sticks to the window and I plug it into the cigarette lighter.
I should sell all my old WinCE and Windows gear before it becomes laughably outdated.
456733
Follow Up By: Parso - Tuesday, Jun 07, 2011 at 21:04
This matter has been driving me mad!
Is your GPS reception ok in remote areas without 3G reception, etc?
Do you need the iPad mounted on your dashboard for gps reception?
What mount did u use?
I have been a passionate OziExplorer user with Hema Navigator backed up by a 7" 'chinese' tablet running Windows CE and Oziexplorer.
You are saying that u would give these the flick?
Parso
729840
Follow Up By: mikehzz - Wednesday, Jun 08, 2011 at 00:10
Here we go again :-)
You need the 3G version of the ipad to get the gps chip but you don't need 3G or any mobile signal to get gps reception. You also need the maps installed on the ipad before you leave
home or you will have nothing to look at.
Mike
729857
Follow Up By: Parso - Wednesday, Jun 08, 2011 at 09:45
Thanks Mike, but what I was more interested in is whether I can import my existing .wpt and .rte files into BitMap.
729875
Follow Up By: mikehzz - Wednesday, Jun 08, 2011 at 11:17
In Ozi on your computer you need to convert them to kml files. Then I think they will come into Bit Map. Bit Map is great at doing simple things like reading the Ozi formatted maps and showing your track in live time, but it has nowhere near the functionality of even Ozi CE. At $4.95 that's not a problem :-) Mike
729883
