noisy bearing
Submitted: Saturday, Nov 22, 2003 at 15:36
Steve from Albany
Does anyone know how hard it is to change the pulley bearing in an air conditioner compresser? Is it a job for an amateur mechanic or should I leave it to the Pros?
Reply By: Nav 80 - Saturday, Nov 22, 2003 at 17:06
Steve,, I would leave it to the pros, its an easy enough job if you have the tools. The bearing is in behind the clutch but you need the proper puller to get the pully off the shaft. There is also an electrical coil behind there for the electric clutch and unless you have the proper tool you may damage the coil.
38113
Follow Up By: Steve from Albany - Saturday, Nov 22, 2003 at 19:50
Thanks Nav 80. I'll take your advise.
27667
