Engel Fridge Temperature Indicator
Submitted: Monday, Jun 06, 2011 at 11:53
ThreadID: 86795 Views:8516 Replies:5 FollowUps:3
The digital readout on my Engel 40L fridge is not working. Fridge still works fine though.
Is there a fuse somewhere or is it back to the shop for repairs??
Reply By: Member - Troll 81 (QLD) - Monday, Jun 06, 2011 at 11:55
There is a little battery you need to replace. Under your lid should be instructions on how to do that.
AnswerID: 456570
Follow Up By: anglepole - Tuesday, Jun 07, 2011 at 18:20
X2. I just replaced my battery in the Engel just follow the instructions.
FollowupID: 729800
Reply By: member - mazcan - Monday, Jun 06, 2011 at 12:16
hi deserter
remove the lid from its hinges by wriggling it back and forth sideways and the screws that hold the hinge plates on
and there are 2 scews on the upper end of the fridge also remove them ease the black cover up and you will see the battery container twist it with a coin and replace the battery make sure you take note where the + sign is facing
you may have to give the battery holder a light tap to dislodge the battery it is an LR76 3v buy one from a store /chemist where there is a constant turnover or test it before you install as it needs to be above 3volts or it wont last long
i have found they last about 12 months
when replacing the black cover make sure you get it in the right position or you will have trouble
put each screw in place and give a couple of turns and repeat until they are all in then tighten all up
been there done this many times hope this is of help
have a fridgin good time
cheers barry
AnswerID: 456572
Reply By: Member - Stephen L (Clare SA) - Monday, Jun 06, 2011 at 14:20
If your fridge is reasonably new, it is a CR2032 Lithium battery, but if older, the first series that had the digital readout used an LR44.
The only reason that they changes to the bigger battery was battery life. The LR44 were only good for around 12 months and they claim that the CR2032 is good for 3 years. I personally got just over 4 years out of my battery.
They are easy to install and will take you less that 5 minutes.
Smile like a Crocodile
AnswerID: 456595
Follow Up By: member - mazcan - Monday, Jun 06, 2011 at 14:37
hi stephen l
its good to know they have made an improvement to the capacity of the battery on 40ltr engels
you are correct with the LR44
but the LR 76 and MS76 do also fit as i have used both in the past
barry
FollowupID: 729635
Reply By: landseka - Monday, Jun 06, 2011 at 17:01
Bugga, this thread mad me go and check my 40L. It will be 4 years old in August so I guess I will be up for a 2032 soon.
AnswerID: 456612
Follow Up By: Member - Stephen L (Clare SA) - Monday, Jun 06, 2011 at 18:50
Hi Landseka
Don't worry, they do not break the bank at around $2.50 each. The only reason why I changed mine after 4 years was that we were heading off for a few weeks and where we were going, I do not think that they would have had any and I knew that the battery must be getting very close to the end of its working life. It is a very simple job to do.
FollowupID: 729679
Reply By: deserter - Saturday, Jun 11, 2011 at 12:22
Crikey - I only just remembered I had posted this !!! Old Timers Disease LOL !!! Thanks all for the excellent advice.
AnswerID: 457061
