Water Tank in Caravan
Submitted: Sunday, Jun 05, 2011 at 16:22
kevmac....(WA)
I know this sounds like a stupid question, but should my
water tank have a plug fitted at the fill spout, or be left open?? If plugged will that necessarily affect the operation of my 12 v water pump?
Reply By: Roughasguts - Sunday, Jun 05, 2011 at 16:30
NaH they don't need a plug theres a breather in there for filling.
Cheers.
456456
Reply By: Keir & Marg - Sunday, Jun 05, 2011 at 16:31
Normally they are fitted with a plug to stop insects, etc getting in. The tank has a separate air breather so that air can enter when you are pumping water out of the tank, either manually or using an electric pump.
456457
Reply By: kevmac....(WA) - Sunday, Jun 05, 2011 at 16:38
Thanks for such quick response ppl ! Is appreciated
456459
Reply By: Ozhumvee - Sunday, Jun 05, 2011 at 18:06
To make a plug for the filler neck buy a plastic chair foot the correct size to be a snug fit and screw a stainless self tapper about 50mm long into the centre of it so you have a handle to remove it when necessary.
Using corks or rubber plugs they tend to soften and stick over time where the plastic chair foot works
456469
Follow Up By: kevmac....(WA) - Monday, Jun 06, 2011 at 21:52
thx for that one Ozhumvee...probably cheaper too
729725
