Garmin 760 Problems
Submitted: Saturday, Jun 04, 2011 at 19:28
oldpop
Having problems with my 760 keeps locking up particularly when in view map mode not so bad when destination selected
any ideas
Reply By: Member - John Q (QLD) - Saturday, Jun 04, 2011 at 21:01
Interested in any responses as I'm having a similar problem. It happened after I updated the maps & I contacted Garmin & was told to run the update again to see if that fixed the problem. No luck though.
456393
Reply By: Member - Ian W1 (QLD) - Saturday, Jun 04, 2011 at 22:10
Hi Oldpop, I've had 3 Nuvi 760's in about 20 months because they kept on freezing up. I rang Garmin and they replaced each one under warranty...no problems. The last one they sent me is still working fine and they sent that one to me about 7-8 month ago. Initially not happy with the product due to reliability but can't complain about the service so try calling them and see if they'll cooperate.
Good luck
Ian
456398
Follow Up By: Bonz (Vic) - Saturday, Jun 04, 2011 at 22:59
Had the same with a 3790T, third one is going gangbusters!!!!
729460
Reply By: oldpop - Sunday, Jun 05, 2011 at 07:04
Thanks for the feed back will see how I go
Oldpop
456410
Reply By: joe99 - Sunday, Jun 05, 2011 at 12:01
Hi oldpop
I have been using a Garmin 760 as my main navigation device for a few years and found it quite reliable.
Have you checked what firmware version your are running?
To find out, press "Tools", "Settings", "System", "About"
My device shows Software Version 4.80
I have been advised against upgrading to version 4.90 due to reports of lockups.
I believe Garmin did release a version 5.1 but withdrew it akmost immediately due to too many problems.
There is also an issue in that if you update to a new map, the device software often gets updated also.
It is possible to "downgrade" your software to get back to an earlier version, but if you wish to do this I would suggest you seek advice from real experts (such as GPSOz) rather than relying on advice from users such as myself.
joe99
456433
Follow Up By: oldpop - Sunday, Jun 05, 2011 at 15:49
Hi joe99
Just checked the unit it is running 4.90 will see if I can get earlier 4.80 and try that
Thanks for your reply
Oldpop
729522
Follow Up By: joe99 - Sunday, Jun 05, 2011 at 19:27
Another thing I should have mentioned is that when you do a "downgrade", your own data (such as favorites) may get deleted so be sure to back up everything first.
If you have trouble finding old software downloads, go to
http://www.gawisp.com/perry/agree.html
and proceed carefully.
joe99
729558
Follow Up By: oldpop - Sunday, Jun 05, 2011 at 19:33
joe99
Thanks very much for that could not find it myself will give it a try
Oldpop
729561
Follow Up By: oldpop - Monday, Jun 06, 2011 at 16:45
joe99
I Installed 4.80 and it looks like it has fixed my dramas
thanks for the info
Oldpop
729656
