Access to Goulburn River N P Camping Areas
Submitted: Friday, Jun 03, 2011 at 18:06
ThreadID: 86738 Views:1670 Replies:3 FollowUps:6
Can Anyone tell me the easiest way in and what the roads are like ?
Reply By: Fred G NSW - Friday, Jun 03, 2011 at 18:14
Would help to know where you will be coming from ???????????
Fred
AnswerID: 456286
Follow Up By: Member - Max H (NSW) - Friday, Jun 03, 2011 at 20:10
Thanks Fred, We will be coming from Merriwa Max.
FollowupID: 729328
Reply By: Member - Mark (Tamworth NSW) - Friday, Jun 03, 2011 at 18:57
Been through it a few times when travelling between Mudgee and Merriwa via Wollar.
80-100km/hr is possible, with caution on corners in a 4WD. Never attempted any firetrails etc, just the through road. Relatively good roads on sandstone base
AnswerID: 456295
Follow Up By: Member - Max H (NSW) - Friday, Jun 03, 2011 at 20:14
Thank-you Mark that is a good start.
FollowupID: 729329
Reply By: Member - Jack - Friday, Jun 03, 2011 at 20:16
Fred is right. Where are you coming from?
I came in via Meerriwa, drove through the NP, out the other side, did a right hand turn and drove back into it again to reach the camping areas.
The road into and through the NP and camping areas is good .. corrugations in parts but do-able if you just take it easy. There are a couple of steep parts but easy to get over.
The first camp ground looked nice, but we chose to go on the '4WD only' road to the other campground, which had a view of the river. My own thoughts afterwards was that the first camp area was nicer. The only reason that the road is signposted '4WD Only' is, as far as I could see, because it has a couple of sizeable dips which might trap a caravan. We towed a Tvan in with no dramas at all.
Jack
AnswerID: 456309
Follow Up By: Member - Max H (NSW) - Friday, Jun 03, 2011 at 20:47
Hi Jack, We will follow your tracks ,sounds like it is quite straight forward,
Happy Camping
max H
FollowupID: 729344
Follow Up By: Member - Jack - Saturday, Jun 04, 2011 at 08:16
Hi Max.
I had meant to add that my wife and I were there for a couple of days 2 weeks ago, so the advice is pretty current.
Jack
FollowupID: 729365
Follow Up By: The Original JohnR (Vic) - Saturday, Jun 04, 2011 at 08:24
Have been in there with a Kimberley Karavan but you would be asking for trouble dragging an on-road caravan there. You need higher clearance with dips and the like.
FollowupID: 729366
Follow Up By: Member - Max H (NSW) - Saturday, Jun 04, 2011 at 20:18
Thanks Everyone for your info we will be there in a couple of days
Max H
FollowupID: 729440
