Utillity for towing a 2 ton van
Submitted: Wednesday, May 25, 2011 at 20:51
chris a
G DAY EVERY ONE
I am thinking about getting a second hand ute for towing $ 15.000 to20.000 . A 2wd not a disiel
how would a Falcon ute go
Have Ford made one for towing
thanks guys
Reply By: Member - nick b - Wednesday, May 25, 2011 at 23:54
Plenty of
sedan towing van around but you will need to
check towing weights etc . re ford ute a bit of weight in back over rear wheel will help !!!!
455485
Reply By: Member - Bucky - Thursday, May 26, 2011 at 05:45
Chris
Any ute is light in the rear end, and the van could actually end up steering you.
Having said that there are plenty of ways to combat that problem. Mainly a couple full sandbags.
There is the 1 Tonne ute as
well, and they are a good vehicle, but again, very light in the tail, but towing capacity should not be a problem.
Ford actually turned out a Ute for farmers & the "Tradie", but I cannot remember it's name. They actuallt sat up higher, and came with some sort of diff lock, as standard
Bucky
455493
Follow Up By: Member -Dodger - Thursday, May 26, 2011 at 16:39
It was Called the ...
LONGREACH.
Had extra fuel tank etc. and for towing would be ok provided you had a bit of cargo on the back or in
the tub.
Just your usual outback gear and perhaps a couple of containers of water etc.
728456
